How do I open fireplace to clean out
Need to open up to clean out inside
  • 3,382 Answers
Great question but we need to know what you have
Posted on Dec 10, 2014
How do I clean the inside glass on my electric fireplace
To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well.
Cleaning Steps
1.Disconnect from Power Supply Before beginning to clean your electric fireplace, turn the heater off and allow to cool completely. Always disconnect the electric fireplace from the power supply before cleaning.
2.Check the Electrical Components Check any wires and plugs to make sure that they are not worn or frayed. This is a rare occurrence, but can become a fire hazard if not addressed. If this happens, consult a professional to repair or replace before using your electric fireplace again.
3.Clean the Heater With a clean, dry cloth, wipe down the surface of the heater. Using the soft brush attachment of a vacuum cleaner, gently clean the heater outlets. This will remove any dust or debris from the heater and keep it running at top performance.
4.Clean Both Sides of the Glass Follow the instructions in your owner's manual for removing the front glass panel. Once removed, you can clean both sides of the glass. Do not use abrasive cleaners, as they will scratch the glass. Dust can be easily removed with a clean, dry cloth. Fingerprints or other marks can be removed with a damp cloth; dry the glass with a lint free cloth to prevent water spots from forming.
5.Dust the Interior Dust may accumulate inside your electric fireplace, like any other unit in your home. To remove any dust, simply use a clean, dry cloth to wipe down the interior. Gently dust any media such as logs or glass inside your electric fireplace as well. When you are finished, place the front glass panel back onto your fireplace following the instructions in the owner's manual.
6.Remove the Soot Just kidding! You never have to worry about dirty, grimy soot with your electric fireplace. Instead, just relax and enjoy!
Nov 14, 2017 | Miscellaneous
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
When I turn my electric fireplace on, the fan blows for about 30 seconds and then quits blowing.
How to revive/lubricate your fireplace blower fan or any ...
? 26:34
www.youtube.com/watch?v=JbX_XtKS1p0
Jan 30, 2013 - Uploaded by varietytubechan My fireplace blower fan had stopped working. ... This is demonstrated on a FK4, GFK4, R7-RB74K (Electric Motor Warehouse), HB-RB74K ...
5 Electric Portable Fireplace Repair Tips ' DoItYourself.com
www.doityourself.com/stry/5-electric-portable-fireplace-repair-tips
Electric portable fireplaces are a convenient way to warm a room, barn, patio, ... If the light or coloring of the fireplace is not working, you may need to replace the ... is not working as well as it should, you may need to inspect and clean the fan.
Oct 26, 2015 | Dryers
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
How do i clean the inside of an amish fireplace
I was told to tip the amish fireplace and hold it about 6 inches away from the floor for about 20 seconds then set it back up you can here it reset inside and I was also told they are self cleaning hmmmm I also had mine for more than the warranty and they sent me a new insert at no charge. Cannot beat that I have to call them again casue it runs for a bit then shuts down again all in all they have been great to me and it heats great too
Mar 29, 2012 | Napoleon Heating & Cooling
We have a GTi model 5000 GDV gas fireplace that is on the outside wall and is about sixteen years old. We have never used it we bought the house when it was nine years old. This year we decided to use it....
Sorry to read about your problem, I hope this helps you out.
well first, clean out the vent exhaust. after all those years, who knows whats inside...you must have burned off dirt and dust. unless the unit has fans in it and they are defective....
I suggest to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Heating & Cooling
HOw do I clean the inside glass of my fireplace?
The decorative surround of your fireplace should easily be removed (if it is anything like mine) and you should then see a number of fixing screws which hold the glass in place.
Remove these and the glass will come out (take care not to let it fall).
Jan 05, 2010 | Watches
Leaking smoke into loft
The outdoor fireplace should not have smoke in the loft. Have you tried cleaning the unit and making sure to remove any remnants of previous fires? The burning ashes could be causing the increase in smoke. I think that you should be able to find a solution that does not involve adding a liner, but I would try a thorough cleaning first.
Nov 24, 2009 | Spirit Elements Outdoor Fireplace Open...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
