WHICH UNIT REPLACE PUH18EK
NON
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
I have the 7410:0043689 error
This error 7410 is a Drum unit non- installing error. The drum unit is not installed or not installed properly.The drum PWB EEPROM does not communicate normal. Detaching and refitting the drum unit;
Procedure
Remove the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
5. Open the left side cover and then remove the waste toner box.
6. Unlock the drum unit lock and then remove the drum unit.
7. Check or replace the drum unit and refit all the removed parts.
Good Luck
Jun 04, 2013 | Kyocera FS-4000DN Laser Printer
Can i replace my 2008 non bluetooth lincoln navigator system with a later year?
You are talking about the stereo right?
You can always upgrade your stereo, but be aware that any steering wheel stereo controls will likely not work with a non standard stereo unit.
Nov 03, 2012 | Cars & Trucks
Leakage in racket pin
If your rack and pinion steering unit is leaking power steering fluid, you most likely have blown a seal in the unit. These are gennerally non-repaiable. Replace the rack and pinion unit. Not an easy job, but an intermediate knowledge home mechanic can do it.
Jun 13, 2011 | 2001 Oldsmobile Alero
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
installed properly.
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
KYOCERA PRINTER GETTING THE FOLLOWING ERROR CODE: SERVICE CALL 7410:0078596
installed properly.
normally.
1. Install the drum unit
2. Check the connection of connectors drum
3. Replace the drum unit
4. Replace the engine PWB
Mar 03, 2010 | Kyocera FS-4000DN Laser Printer
I need to replace the stainless skin on my freeze
You will most likely need new drawer unit Warner's Stellian in Saint Paul, MN can help. For cleaning DeBruce Polish is the best.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Jan 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dashboard lights burned
You can not. The unit is a solid state, with a circuit board on the back. non repairable bulbs.
You should take to dealer , there is an open recall on the dash assemlby. Chevrolet will replace the unit with there exchange program.
Aug 14, 2009 | 1995 Chevrolet Tahoe
Vented vs. non-vented dispenser unit
If you cannot get a non-vented unit, just buy the vent fitting that fits onto the dispenser unit....it runs accross the door panel and down the door to the gutter in the bottom of the door. There should be no problem using the unit "as-is", but if you see small amounts of water dripping from below the outer door panel, get the vent tube. It should be inexpensive. Oshie
Jun 17, 2007 | Bosch SHU5316UC Dishwasher
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
