Question about Xerox Phaser Office Equipment & Supplies
Have a Xerox 8560mfp I am getting a system error message of 39 003 40 18871 what is that and how can I fix or find part if needed
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 23 Answers
That error indicates a failure with the scanner assembly, the whole upper assembly needs replacing. if you need the part, please contact me.
Posted on Dec 20, 2014
Nextgen
  • 13 Answers
SOURCE: 8560mfp system error 07,010.43:2640
The error you are receiveing is due to the printhead in the machine most likely being stuck in the tilt position by the tilt lock arms. The first step is to reboot the machine, which you have already done. The rest of the possible solutions require disassembly of the machine. They include:
  1. Verifying that the lock arms are rotating properly.
  2. Examining the printhead for spilled ink.
  3. Checking the process motor gears for damage.
  4. Checking the process gear box, shaft and drive module are in home position.
As well as a few others.
If the machine is new, I would suggest having it looked at under warranty by a Xerox tech. It sounds like something they would cover.
Hope it helps!
Posted on May 21, 2008
  • 2072 Answers
SOURCE: system error on Xerox 8560MFP
Bkack ink stick is most likely stuck in the loader.
I would suggest checking all the sticks for being cracked twisted or otherwise stuck.
If you need to remove them take a screw like a drywall screw and twist into the stick and slide it out and back. I think the .46 means a black stick, but at any rate, one of the ink sticks has not loaded all the way down the ink loader.
Posted on Dec 05, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560MFP/N System error
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Posted on Jul 31, 2009
  • 26 Answers
SOURCE: our xerox printer phaser 8560MFP does not work and
This error code specifically means: "The media path motor stalled while moving the cap/wipe down."
In English, there is a component inside your machine that is either moving too slow or is obstructed by something.
This can either be very serious or can be surprisingly simple.
If I were you, this is what I would do:
1) Make sure the waste tray is empty.
2) Make sure there are no paper jams or paper scraps anywhere.
3) Check the preheater and make sure there are no obstructions.
4) Replace the mainten
ance kit. See link below.
*This ensures that the printhead is properly lubed and is not dragging behind or stalling
5) If it still does not work, bring it to your nearest Xerox Partner.
If the top suggestions did not work, the problem must be very serious. Your average person cannot fix the problem themselves with any motors or gear packs.
Good luck. Please rate my response or post a comment on your original question to allow me to further assist you.
Maint. Kit:
http://www.office.xerox.com/product-resources/108R00675/enus.html
Find a Partner:
http://www.office.xerox.com/cgi-bin/resloc.pl?what=Service
Posted on Aug 18, 2009
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
ERROR MESSAGE 09,006.41:150694
A solution has already been posted for this error:
ERROR MESSAGE PHASER 8560 09 006 41 150694
My printer xerox phaser 8560mfp is printing landscape 1/2 page instead of a full size portrait from a pdf file. How do I get that fixed? Thanks!
You need the new driver. Goto the Xerox website and download the latest driver and save it on your C: drive. Goto Devices and Printers and remove your existing Xerox 8560MFP. Reboot your computer and go back to this screen and click on "add a printer". When you get to the screen "Install the printer driver" you will see Xerox 8560MFP PS highlighted DO NOT CHOOSE THIS! (you will simply be installing the same driver from Windows 7 back). Instead, Click on "Have Disk... and navigate to where you saved the driver. Choose that one and finish the install.
May 20, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser WorkCentre C2424 System Error: 39,003.40:63581 Do you know what this error is indicating and how to fix it?
Sounds like that is a scanner error, you should replace the lower scanner assembly Part # 109K01870.
Other scanner errors include 39,002.40 39,003.41 39,004.42 and 39,005.43 (any numbers after the semicolon is the page count)
You can order the part here
Here is a video that shows you how to replace it
Mar 17, 2011 | Xerox Phaser 8560MFP Laser Printer
System error code 07,010.43
This is a Process Drive, or a printhead error.
The printhead is probably stuck, or not tilting properly over the drum.
You will need a service technician to fix this.
Dec 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560MFP/N System error 07,010.43.14452
The probable situation is that 2 camshafts (020K14800 & 008K02160) have cracked, and now have taken out the Process Motor (127K53240)
Replace all 3 together, and get the "homing the process motor" and "homing the head tilt mechanism" instructions.
-Whit :)
Jun 23, 2009 | Xerox Phaser 8560MFP Laser Printer
8560 System Error 39,003,40:6082
Replace the scanner assembly(flat bed)
Mar 12, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
