Question about Vizio E470VA 47" 1080p LCD TV - 16:9 - HDTV 1080p - 120 Hz -ATSC -NTSC -4 x HDMI
How do I fix a Vizio E470VA. The unit takes a impossibly long time to respond to the remote control power on. The power button on the TV does not work. While on the buttons on the TV do not correlate
I hold the power button on the remote control for a long time until the TV powers on.
  • Vizio Master
  • 1,249 Answers
Try a warranty claim or have a tv shop do an estimate.
How do I fix a Vizio E470VA. The unit takes a impo - 12_10_2014_8_44_07_pm.jpeg
Posted on Dec 10, 2014
Testimonial: "It's past it's warranty date. I got the approx 3 years ago"
  • jeff5may32 Dec 10, 2014
    These units are built like laptops and cell phones, delicate parts inside that are expensive. Not easy to work on, let a shop handle the repair.
How do I fix the TV if it wont power on
Power supply is the first thing to check out.
Dec 08, 2015 | Vizio Televison & Video
Vizio remote won't control tv
I just had the same problem. I call Vizio and this is what they had me do that did fix the problem.
1. Unplug the TV
2. Hold down the power button on the TV for 30 seconds (yes, with it unplugged and do not plug it back in yet.)
3. Take the batteries out of the remote.
4. Press each button remote twice to ensure that they bounce back and are not stuck.
5. Place new batteries into the remote.
6. Plug the TV back in. Not into a power strip if possible. ( I did not have an available outlet so I used a power strip.)
7. Try turning the TV on using the remote. (My TV turned on. All of the functions worked - problem fixed.)
Hope that this helps.
Nov 17, 2013 | Vizio New Original M3D550KD Remote Control
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
Menu button stopped responding
If only one button does not work at all or all do not work the unit may have a lock out feature that would be explained in the owners manual.
Apr 10, 2012 | Vizio Televison & Video
My universal vizio remote needs to be reset to my sony t.v. i have no clue on how to reset it and i dont have the code any more can you help me please?
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Aug 29, 2011 | Televison & Video
I have 4 TVs using 2 receivers. TV 1 and 2 use receiver VIP722K. TV 3 and 4 used receiver 322G. I bought a new Vizio tv to replace TV 4. (Note: TV 2 is also a Vizio) I tried to set up the new Vizio...
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your question and wanted to see if I could help. It sounds like youmay need to either readdress your TV4 remote to your 322 DISH receiver or youcould possibly have receivers for TV2 and TV4 mixed up. Since your TV4 has "Pressselect to watch TV" on the screen you can check both of your receivers andwhich ever receiver has the TV2 blue light off is the receiver this TV runs offof. If this is not the case and you are positive that the TV4 does run off the322 you will want to take the remote to the receiver box location in order toreaddress it. I will list here for you the instructions for readdressing theremote to the receiver box. I hope you find all this information useful and ifyou have any other questions or this does not fix the issue you are experiencingfeel free to email me at Cheri.Torres@Dishnetwork.com. Thanks and have a greatday!
Instructions for readdressing your remote to your DISH receiver
  1. Go to System Info screen. You can do this by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address and secondary remote address.
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the little white square for secondary remote address.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Feb 16, 2011 | DISH Network IR Remote Control
My friend has a Vizio model E470VA and Dish network. But the Dish remote will not control the volume / mute on the tv reliability. The on/off button works perfectly. Remote has been replaced also...
Hello, my name is Becki Barned, and I am with Dish Network customer service. To program the remote to a Vizio tv, there are a couple approaches that you may take. First is, follow this link: http://www.dishnetwork.com/SupportSection/power-scan-instructions which walks you through it. Or do these steps: 1. Hold down the TV mode button until all mode buttons at the top of the remote light up, then release. 2. Punch in the code 505. 3. Press the pound (#) button on the keypad. Use either of these, and that remote will work great! Just make sure after you get the volume working, that you press the SAT button on the remote! If you have any other questions, blog back, or you can find us on Twitter!!!!
Dec 18, 2010 | DISH Network IR Remote Control
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio E470VA 47" 1080p LCD TV - 16:9 - HDTV 1080p - 120 Hz -ATSC -NTSC -4 x HDMI Logo
80 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
