Question about Shark Vacuums
I have an older shark vacuum. It has no suction. There is a small rectangular opening on the side of the canister that air is being sucked through. If I cover the openeing with something or my finger
I don't remember the model Shark I have. It was purchased approximately 5 yrs ago.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Put tape on it
Posted on Dec 12, 2014
Suction when vacuuming
Some vacuums have a valve or collar near the handle that you can twist to adjust the amount of suction on the vacuum. If you open it a little it will stop sucking up your throw rugs. IF the problem is not enough vacuum then the HEPA filter may be clogged. It's usually a rectangular filter in a plastic frame. That has to be changed occasionally or the suction of the vacuum will continue to drop off.
Apr 04, 2015 | Vacuums
Chess piece lost in shark navigator rotator
You must extract the chess piece or else it could move within the unit and cause further damage. If you cannot open the shark and get to the intake section, then have a service do it for you.
Feb 26, 2014 | Shark Helmet NV22L Shark Navigator Upright...
There is no suction in my vaccumm
CHECK LIST
1. Full or clogged dust bag.
2. Dirty air input filter.
3. Wrong pile height setting.
4. Open suction control.
5. Hole in hose.
6. Canister hood open
this link is for the manual
http://www.sharkclean.com/manual/EP238_0602A_1yr_warr.pdf
Sep 26, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
My Shark navigator is making a very loud swooshing sound out of side of canister.
I had the same noise coming out of the side of the canister although I would specify it as a sucking noise. The noise is coming out of a hole on the side of the canister. If you block the hole it sounds normal. This lead me to believe that there was no damage. After further research I found that this whole is actually a release when air cannot make it through the top of the canister. Simple resolution. Take the canister out of its holster and clean both the top part and the metal cone inside and your vacuum will work good as new :) ~=MaGiC=~
Feb 04, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Very little suction when vacumming
Hi There,
I think I know exactly what the problem is with your Dyson. I'd be happy to try and walk you through it, but just want to make sure that you still need help, or if you've already fixed the problem.
Apr 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt needs fixed after sucking up a soft rug.
if its a canister model there probably is no belt just suction.open the canister and if it has a bag feel the bag ,if it feels kind of hard then the bag is full.take the tool off the end of the hose and turn it on to see if you have suction if you do then the tool is blocked up.take it to the sink and run some warm water through it and maybe use a little brush to clear out the dirt.full bag will cause your vacuum not to have suction or not as much as it should
Apr 09, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
I have a dyson that is picking up just fine when on vacuum mode, however when I try to use the suction tube there is no suction at all. It is not blocked and the canister is empty. Help!
Hi, I have an upright DC03, brilliant machine. Mine wouldn't **** and had the following symptoms;
- it sucked ok from the top hole where the canister joins the unit - with the canister the dust didn't spin aroun inside the canister like it normally does and there was no **** at the hose end or brush end. - with the top of the canister attached (the cyclone) but not the bottom it sucked through the cyclone - the small valve on top of the cyclone unit was sucking heaps
this indicated to me the machine was sucking through the cyclone unit but when the canister was put on it was blocked - hence the tremendous sucking through the valve on the top of the cyclone. As far as I could see the cyclone wasn't blocked so I poked some wire down the tube inside the machine that runs from the bottom of the unit (where the hose sits) up to the bottom hole where the canister joins.
The DC03 has 2 holes where the canister attaches, it seems like it sucks air through the top hole, through the cyclone and through the lower hole sucks the dust up this inner tube into the canister. Check that tube, shine a torch from the top hole and you should be able to see the light at the bottom. Make sure you clear it completely.
Mine was very very blocked. I kept poking and removing dust until I could see light at through the tube. Works fine now.
Hopefully this helps someone as it took me awhile to work it out.
Good luck
Aug 12, 2008 | Vacuums
Help needed pronto!!
Most vacuums are make to suck not blow. Except for the Rainbows or Rexair vacuums. They have a port for blowing air.
Oct 30, 2007 | Vacuums
Vacuums Logo
265 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
