Question about Golds Gym Gold""s Gym Power Spin 210U/230R/290U Power Supply / AC Adapter"
U SPIN 210 INSTRUMENT PANEL NOT WORKING FULLY. hOW DO I FIX?
UNPLUGGING AND PLUGGING BACK IN
Have a 2002 pontiac sunfire . mostly in winter all the gauges stop working. Turn car off then back on goes back to working.
Bad connection at the plugs on the instrument panel. Usually unplugging them and plugging them back in takes care of the problem. Some times the plugs need replaced.
May 21, 2015 | Pontiac Cars & Trucks
How do i fix speedometer and gauges that quit working at same time. on 2004 ford exloder(explorer)???
There is a fuse for the gauges. If it is good then you will have to pull the instrument panel(IP). Unplug it and plug it back in first( Don't put it back together yet). Bad connection. Then chase the power wire from the fuse panel to the IP. The gauges run off one fuse, but different sources.
Mar 17, 2015 | Ford Cars & Trucks
I unplugged my cigarette lighter to fix the dash and now my dash gages don't work. Things like my gas gage, temp gage, ect. Where do I start to fix this?
your main plugins have become disconnected ,,there are individual plugs like for your instrument panel ,,,headlamps as well as all plugins ,,you apparently will have to remove your dash back some or crawl under it to ensure all components are plugged into the proper areas ...Note everything must be plugged in ,,leave nothing out
Oct 27, 2013 | 1994 Ford Econoline
1997 caravan sport, gas ,rpm,heater,speedometer gauges ,doesnt work. every thing else works, all lights,horn,turn signals,etc.?
There is likely a bad electrical connection at the back of the instrument panel. Remove the instrument panel, unplug the connectors, clean the contacts on the plugs and the panel with rubbing alcohol and q tip, and reinstall.
Aug 30, 2011 | Dodge Caravan Cars & Trucks
My oven and cooktops do not reach high temperatures is it because i have 210 volts reaching the range?it must be 220 v exactly?
no you need to double check the breaker. Best thing to do is to flip it all the way off and then wait a minute and flip it back on. Make sure it stays in place in the on position. Your electric range or dryer can act as though it is fuctioning by all the lights working and timer or on a dryer it can spin but not fully heat. This is caused by a bad breaker or one of the two legs of the 220 not working from the main breaker panel. Using a meter you can test and see if you are getting the 220 or if it is only registering about half of that. 210 should be plenty to fully heat up. Hope that helps. Double check that breaker and make sure it fully locks in the on position.
Jun 06, 2011 | Whirlpool Kitchen Ranges
1996 dodge ram v10 , the instrument and gauges just stop working ,can't find fuse for instrument cluster, can you direct me in the right direction.
It's the plug for the panel. The trim bezels just pop off to access the screws to remove the instrument panel. Usually unplugging it and plugging it back in fixes the problem. Also there is not a fuse for the guages, just the illumination of the panel.
May 22, 2011 | Dodge Ram 2500 Cars & Trucks
Line 6 spider 210 volume problem
The bypass switch in the headphone jack is likely broken. NEVER unplug the headphones while the amp is on.
There are certain small amps that have a possibilty of popping the power amp due to a feedback arrangement. Likewise, never use the headphone jack for ANYTHING other than headphones.
Dec 20, 2009 | Music
Instrument panel cluster gauges and odometer has stopped working
I had all my analog instrument panel gauges stop working after they did the state emissions test. I found the proper fuse in the fuse block located under the hood. Simply unplugged the fuse, noticed it was still good, and plugged the same fuse (10A) back in and all the gauges started working again. Guess it needed a reset atfer they plugged in for the emissions.
Mar 19, 2009 | 2003 Chevrolet Silverado 2500HD
Simplicity air conditioner
I had an e1 error, the fan was spinning but the compressor dosen't.  I don't know witch step i made fix the problem but try it.  I unplug the air conditioning for few minutes, unplug the control panel, get every things  back and it's work fine.I wish that can help youFrançois
Jul 10, 2008 | Kitchen Appliances - Others
Losedash electrical
I have the same problem.
Jun 24, 2008 | 2000 Jeep Cherokee
Golds Gym Gold""s Gym Power Spin 210U/230R/290U Power Supply / AC Adapter" Logo
108 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
