Question about Minwax 6 Oz Stainable Wood Filler
I need a product to glue 2 wood pieces together of a broken statuette.
Nothing yet.
  • 3,506 Answers
White glue is good but the pieces will need to be held tightly together for at least 12 hours and more would be better up to about 24 hours. Any excess that runs out can be easily wiped away with a wet cloth etc.
Posted on Dec 11, 2014
What can i use to glue wood together?
at the hardware shop there is a product called liquid nails
pull the items apart , install the liquid nails and press them back together
the product doesn't fail with age and is far superior to wood glue
Oct 19, 2017 | Cars & Trucks
Kitchen drawer, particle board repair.
It is far better to replace the drawer front altogether. Glues and adhesives actually make particle board swell and cause it to disintegrate so if it is splitting there is no sound way to glue it back together and retain any structural integrity. I suggest taking the drawer to a local cabinet maker and have them repair it by duplicating and replacing damaged pieces.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 01, 2014 | Garden
We have a Back To Basics popcorn popper that has a broken piece. The piece is the clear see-through plastic top. Where can we find a new piece?
West Bend took over this company and no longer provides plastic window replacements. I fixed mine by super gluing the window and attaching a small strip of wood on top of the 2 plastic window pieces with small bolts (super glue pieces so wood can be properly attached because glue alone will not hold up to the heat). Not attractive but it works. (West Bend rep told me windows break because of high heat, but I only used mine over medium heat; I think they break at the spot where the raised lid hits the gear mechanism holder.)
Dec 11, 2011 | Back to Basics Popcorn Popper (PC6)...
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
How do i replace a broken wiper lever on the steering column of my 2002 Honda Odyssey van?
You can try using super glue jell to glue it back together cost's a $1.00 and if you can get two ice cream sticks to go in the place where it is broken you can cut the sticks to fit and glue then on each side of the broken area on the side where you push up or down. this is a temp fix but can work if you do it right. If you can't get a ice cream stick then try to find a piece of plastic tubing and make it about 1/2 long before and after the break and then apply super glue to the plastic and slide it over the lever and push the two broken pieces together and slide the plastic tubing over it and hold it in place for a couple of minutes once it has set up for 1/2 try it to see if it works. if it holds you got it made if not the professional way is to replace the switch assembly. let me know if you need more help. I gave you the back yard way to do it but if you want to replace it post to the e-mail you get and let me know and I will give you detailed information to replace the arm. It requires three tool you may not have but can rent at most auto stores.
Nov 06, 2009 | 2001 Honda Odyssey
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
The on button seems to be stuck down on my sony cybershot
The button is made of plastic an one of the tabs i probably broken. If you have the skills to take your camera apart, you can fix it yourself. You can go to the YetiCam.com site, under manuals select Sony DSC-S600 Version 2 (Updated 2/17/07). This will tell you how to take the camera apart. Then you need to take some Super Glue and glue the two pieces back together. Be carful not to put too much glue on the pieces, or the switch will glue itself to the other pieces in the switch cover. Here are a couple of shots of the underside of the cover showing the switch piece. Red circles show the weak points.99f3da3.jpg7325b53.jpg
Jan 27, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Minwax 6 Oz Stainable Wood Filler Logo
64 people viewed this question
Top Minwax Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Minwax Air Tool and Compressor Expert? Answer questions, earn points and help others
