Can a natural gas sterlinge heater be changed over to propane
I want to change it over to propane
    Master:
  • 755 Answers
Yes but you just have to change the ventura which is only a fitting to either make the intake smaller or bigger , I forget which but it is an easy fix , good luck
Posted on Dec 10, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Posted on Oct 16, 2007
hotuna
  • 288 Answers
SOURCE: changing lp heater to use natural gas
Yes. the orifice has a tiny hole in it.It is located at the tip of the pilot before the flame, and at the tip of the injectors. Natural gas and propane molecules are different sizes in the vapor state. The orifice regulates how much vapor comes out. You need to change the orifice in the pilot and the burner injectors for it to work properly. If you don't you will get a very large flame or a very small one, depending which way convert from. If you have the papers from the company that made the heater, they should be able to help you changer over. You also may need to make some adjustment if you are at high altitude, 2,000' or more, as the air is thinner (less oxygen) so the regulator needs to be set to higher volume.
Posted on Mar 10, 2008
hotuna
  • 288 Answers
SOURCE: dyna glo ventless rmc50 ngt
All gas heaters can be converted from one type of gas to another, be it natural or propane. The problem is getting the orifice retrofit parts that fit that particular brand. If the manufacturer doesn't make them, then you are left with no choice.
Posted on Mar 12, 2008
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
clyde2j2
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Can you convert the tankless water heater model # RL94in from natural gas to propane?
Contact Rinna
Some water heaters allows changeover by installing new chipboard or changing dip switches... some do not.
Propane burns much hotter with higher pressure than natural gas
Gene
Water Heater Timers Save Money
Feb 14, 2015 | Rinnai RL94i Tankless Water Heater
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Change orfis in water heater
Do NOT do that.
If you put LP gas to NG heater you can cause explosion.
Contact manufacturer and see if they sell conversion kit. Most do not.
Copy following link for general overview and cautions:
http://waterheatertimer.org/pdf/Convert-Natural-Gas-water-heater-to-LP-heater.pdf
Jul 11, 2012 | Water Heaters
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. dbkohl@prodigy.net 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Pool Heater wont light
NO NO NO the heater is design to work on propane or natural gas only
Sep 10, 2009 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Physical difference between natural & propane orfice
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
