Question about Toshiba 50H72 50" Rear Projection Television
Rear Projection Tv Problem! black and white... Please help
I have a Toshiba 50h72 Rear projection hd tv... It worked fine but now on the regular input channel the tv color is basically black and white....
First it was green black and white, and now just black and white?
what needs to be replaced? and is it a simple unscrew and snap in procedure i could do myself? because i am BROKE and have no money to fix... Thanks for your help
  • rjw123 Nov 11, 2007
    This is what it did look like as it started going bad, and now its just straight up black and white
    its still green like in the picture... not black and white, i was mistaken
  • Toshiba Master
  • 5,138 Answers
Go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Posted on Feb 05, 2008
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works...
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Mar 09, 2009 | Toshiba 50H81 50" Rear Projection...
Need resister
DIgikey should have it. It is a 2Ohm 1 watt resistor.
Feb 08, 2009 | Toshiba 50H72 50" Rear Projection...
The red seems to be out of place on my toshiba 50h72 projection t
Replace both convergence ICs they are stk392-110 you will also need at least the six 1.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free installation instructions so you can do the repair yourself.
heres the link.
Jan 18, 2009 | Toshiba 50H72 50" Rear Projection...
The red in my tv is out of place
you will need to have someone come out and reconverge the tv for you. it shouldnt cost alot but its what you will need to do unless you can do it youself.
Toshiba 50H72 rear projection TV. NO Video
Bad caps and solder connections, especially in around the 9v regulator just about center of the defection circuit... Not a terribly expensive job and certainly worth the repair if the cabinet is in good condition...
Jan 13, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba projection tv 50 inch
Need to test F470 and F850 for open.. Simple continuity to see if either fuse is open.. If F 470 is open replace it and C884 and if F850 is open you probably you may need to replace the two convergence amps STK392-110... Large black Ic's screwed on an aluminum heat sink...
Dec 16, 2007 | Toshiba 50H72 50" Rear Projection...
Mitsubishi rear projection
On every input?? RF (coax),yellow(composite),S-Video and
component (red,green,blue)??
Verify model # please......T.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
436 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
