Question about Digital Watchdog DWC-LPR650 6 to 50mm Varifocal 560TVL Outdoor IR Day/
I have 4 of the DWC-LPR650 cameras installed and running off of the same power supply. 1 of the 4 cameras is intermittently flashing. I have switched the power from 1 of the working cameras to the problem camera but I am still having the same problem. Can you give me other options to try to resolve this problem?
  • Digital Watc... Master
  • 3,368 Answers
Try a separate power supply, if that does not fix it you have a bad camera. If it fixes it replace or repair your existing power supply.
Posted on Dec 10, 2014
I have a Sony digital camera, a DSC-W100 and it has an error code E91-01 with the flash symbol flashing continually. The flash does not operate when taking a photo, and I have initialised the camera as per...
Hello i ill tell you how to fix your camera
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this helped please download the service manual for the camera from the below link it will help with future problems:
http://goo.gl/3PPN7o
Thank you
Sep 04, 2013 | Sony Cyber-shot DSC-W100 Digital Camera
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
Mar 24, 2008 | Cameras
SONY DSC-W220/B My camera is displaying a message E:91:01 and will not flash. What do I do?
1. Turn OFF cam
If this does not work do this:
THE MASTER RESET
(1) remove the battery pack
(2) press and hold the power button for 30 sec
(3) after put the battery back do not turn it on for 1 min
(4) turn on
May 27, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash doesnt work, flash icon keeps flashing, E:91:01 flashing
Hi
Try to reset your camera, heres one way of doing it
1. Turn OFF cam & Remove the battery or the power supply
2. Turn the switch to CAMERA for about 30 sec then & Turn the switch to OFF
3. Install the battery or power supply. & Turn the switch to MEMORY
4. Open the LCD cover and press the RESET button ( small inner button )
5. You will be prompt to adjust date/time.
6. Take some pictures and test out your flash
or open up the setup menu, and look for intilize or reset to factory defaults.
That should solve it, if it doesn't then its a hardware issue possibly the flash is bad some parts may need to be replaced to fix it. Take it to a local repairer or your dealer if your in warranty.
www.advancecamera.com will offer a free repair estimate if your outside of warranty.
Sep 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
Hope it will solve your problem....
Oct 06, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Sony DSC-W50
1. Turn OFF cam
Dec 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Digital Watchdog DWC-LPR650 6 to 50mm Varifocal 560TVL Outdoor IR Day/ Logo
67 people viewed this question
Top Digital Watchdog Home Security Experts
Lawrence Oravetz
Are you a Digital Watchdog Home Security Expert? Answer questions, earn points and help others
