I JUST CHANGED THE BULB ON MY HDTV.NOW WHEN I TURN IT ON THE TV SAYS PLANT DOOR OPEN.DEFINE PROBLEM
  • Leonard Willis
    Leonard Willis Dec 10, 2014
    tHIS IS A 72 IN TOSHIBA HDTV
  • 3,368 Answers
That indicates one of the covers in not in place as it should be.
Posted on Dec 10, 2014
Replace bulb
There is a small access door on the rear panel of the set. Open that door and you will see the lamp cage it pulls straight out.
Jul 08, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I changed the lamp but the lamp light keeps blinking and the tv won't turn on.
3 blinks is the lamp door error code. Try jumpering the door switch. These switches are notorious for going bad.
OR
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
May 18, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TV does not turn on, blinking green on off button.
that should be in the owners manual
techman
most sets havev a small door thathas has a screw on it and the bulb is inside a small cage you pull out
techman
May 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The tv will not turn on. I need to change the bulb in the tv
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
May 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tv went blank blinks green then red 6times won't turn back on even after lamp replacement and lamp was bad
Hello. I just changed my bulb in the same tv. Your bulb and housing is not all the way in . That is why it blinks then turns red. Open up your light door and press it fully in and a tad downwards. It will fix the problem,
Feb 27, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
How to replace bulb on sony kdf-55000
there are 2 hand screws on the back of tv, both sides, loosen them, them remove the lower front plastic cover, it is tight, you will need to pull on it hard after you loosen the screws, when you remove the front cover you will see the lamp access door, one hand screw removes it. 2 allen screws remove the lamp, if you buy a sony lamp, it will come with the allen wrench. if the glass is busted on your lamp it is definately bad, if it's not busted, you might have another problem.
Sep 14, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV powers off for no reason
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
Lg 52sx4d not starting up
The flashing green bulb light means the access door for the bulb on the lower right side of the TV is open or loose. There are two screws that hold it in. If they are tight, maybe the interlock switch is bad or disconnected. Open the door, and hold in the little white interlock button while turning on the TV. If it still doesn't work, there are wires leading from the switch to a connector about halfway across the TV on the bottom. Connector might be loose. Unfortunately, it is hard to reach. You might have to remove the screws across the bottom rear edge that hold in the chassis and gently slide it out to reach the connector.
Mar 01, 2009 | LG 52SX4D 52" HDTV
Rca 175
No, there is a switch that must be engaged or the bulb will not fire. You can't turn it on with the door open or the entire back off the tv with out jumping the switch.
Jul 28, 2007 | RCA HD50LPW175 50" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
