Question about Dishwashers
Does hemalayan salt cause hypertension? - Dishwashers
  • Dishwashers Master
  • 3,382 Answers
It raises your blood pressure which is hypertension
Posted on Dec 10, 2014
What is the meaning of blood pressure 235/100
If it really is 235, you need a hospital straight away. That is embolism, stroke and heart attack pressure.
Should not be more that 140/70
Your blood pressure is 235 over 105? - BloodpressureOK.com
bloodpressureok.com/reading/235-over-105/
But regarding your systolic (upper) value your blood pressure is rather: Way too high - Hypertension Stage 3 / Hypertensive crisis. If you are getting two different ...
Hypertensive Crisis: When You Should Call 9-1-1 for High Blood ...
www.heart.org/.../HighBloodPressure/GettheFactsAboutHighBloodPressure/Hypertens... Jan 18, 2017 - Know the two types of HBP crisis to watch for. A hypertensive (high blood pressure) crisis is when blood pressure rises quickly and severely.
Blood Pressure: 225/132 ' What Does My Blood Pressure Reading ...
https://www.caring.com/charts/blood-pressure-225-132 Learn what your blood pressure of 225/132 means. Find out if your blood pressure levels or readings are normal, too high, or too low -- and what you can do ...
blood pressure above 280 - High Blood Pressure / Hypertension ...
www.medhelp.org > Communities > High Blood Pressure / Hypertension Jun 11, 2015 - Has anyone experienced blood pressure of over 280 close to 300? ... My mother just died (less than a week ago) after her blood pressure ...
Blood Pressure Chart - Normal Blood Pressure Range - Vaughn's ...
www.vaughns-1-pagers.com/medicine/blood-pressure.htm Normal blood pressure range chart, with comments about each blood pressure level. High, normal and low blood pressure are defined. blood pressure 235 100 Google Search
Jul 09, 2017 | The Health & Beauty
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
MY DAD IS 92 YRS, HIS bp IS 98/62, WHAT CAN I DO?
That BP is pretty good. Reduce salt intake and coffee.
http://www.webmd.com/hypertension-high-blood-pressure/guide/diastolic-and-systolic-blood-pressure-know-your-numbers#1
http://www.mayoclinic.org/diseases-conditions/high-blood-pressure/in-depth/blood-pressure/art-20050982
http://www.etoolsage.com/Chart/Blood_Pressure_Chart_by_age.asp
Jul 07, 2017 | Cars & Trucks
Causes high systolic blood pressure
Isolated systolic hypertension can be caused by underlying conditions such as artery stiffness, heart valve problems or an overactive thyroid (hyperthyroidism). For years, doctors focused primarily on diastolic blood pressure. The recommended goal for systolic pressure for younger people is less than 140 mm Hg.
Apr 05, 2017 | Health & Beauty
What is the symptoms of high blood pressure?
High blood pressure is often associated with few or no symptoms. Many people have it for years without knowing it. However, just because high blood pressure is often symptom-less doesn't mean it is harmless.
In fact, uncontrolled high blood pressure, or hypertension, causes damage to your arteries. High blood pressure is also a risk factor for stroke, heart attack, and other cardiovascular problems.
Some of the rare symptoms of high blood pressure are:
Rarely, people with chronic high blood pressure might have symptoms such as:
1. dull headaches
2. dizzy spells
3. frequent nosebleeds
Other symptoms of a hypertensive crisis may include:
1.severe headache
2. severe anxiety
3. shortness of breath
4. nosebleed
Mar 20, 2017 | The Health & Beauty
For age 52 whats my normal blood pressure
A normal Blood pressure for a 52 year-old male is less than 120/80 mmHg.
A Blood pressure reading between 120-139/80-89 is considered pre-hypertension, and greater than 140/90 Is hypertension (High Blood pressure).
Mar 17, 2017 | Health & Beauty
My blood pressure is 176 over 116 and been nauseous im hypertense And i taking pills ,but this 3 las days i been un and I having those symptoms is that Normalor a risk for stroke?
Your blood pressure too high - Hypertension Stage 3
Requirement for hypertension stage 3 is a value of over 180 over 110.
If you are getting these values on multiple checks please consider finding a doctor as soon as possible. http://bloodpressureok.com/reading/176-over-166
Nov 20, 2016 | Health & Beauty
My blood pressure is 110/95 and my heart rate is 124/bpm. I am pregnant what does that mean?
110/95 Blood Pressure
Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic Normal Less than 120 Less than 80 Prehypertension 120 - 139 80 - 89 High Blood Pressure
(Hypertension) Stage 1 140 - 159 90 - 99 High Blood Pressure
(Hypertension) Stage 2 160 or higher 100 or higher Hypertensive Crisis
(Emergency care needed) Higher than 180 Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range.
Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
Aug 05, 2014 | Veridian Healthcare 01-539 SmartHeart Arm...
High blood pressure, blurred vision one eye, headache, dizziness
Hypertension can cause all this, but these symptoms can happen when the pressure is very high, so it must be checked then and controlled so no damage is done to the body.
Dec 15, 2013 | Health & Beauty
Dishwashers Logo
Top Dishwashers Experts
