Question about Lands Phones
How do I get the voicemail red light to quit flashing? I clear it and it keeps coming back on!
Keep Clearing it and it comes back on.
dididsaythat
  • 291 Answers
SOURCE: temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Posted on Sep 09, 2007
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
  • 1779 Answers
SOURCE: tvstopped working, green power light comes on, red light flashing
Most likely it has a power supply module problem. Have it looked at by a qualified service company.
Posted on Dec 08, 2009
welcomejee
  • 10594 Answers
SOURCE: The TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Posted on Jan 26, 2010
  • 186 Answers
SOURCE: red light keeps coming on and green one keeps flas...
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
Posted on May 22, 2010
How do I activate entry?
If this is for the publishers clearing house website, it is a confusing mess and they keep it like that. The more confusing that it is the more you keep coming back and the more they advertise. The issue is designed so that if it is not clear, the odds are no in your favor.
Jan 23, 2015 | Computers & Internet
My check engine and check fuel cap light keep coming on after i changed the gas cap twice and reset the light it came back on what could this be. I drive a 06 lincoln navigator
You need to diagnose any codes you get
& smoke test the evap system, to find a
problem
Seldom does throwing on parts with a name similar
to a code work
Codes have nothing to do with installing parts
Clearing codes, clears all data needed to diagnose
the failed system & the evap system only runs every few
days,so you done as far as codes helping
Mar 22, 2014 | 2006 Lincoln Navigator
NEW MESSAGE LIGHT FLASHES IT KEEPS COMING BASK ON EVEN WITH NO MESSAGES ON PHONE
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Feb 21, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
My 355lm will accept the keyless only and will lock up when adding the remote what solution would you have
First things first. The 355 Lift Master garage door opener receiver will only accept a limited amount of codes.
You can clear the codes and this will most likely fix your problem.
1.:Clearing the codes from the355lm receiver.
You do this by pressing the learn button on the receiver and hold for 20 seconds.
(The LED light will come on and remain on. Hold until the light flashes. When the LED light flashes, this indicates that the codes are clear.)
You may now release the button.
You are now ready to Reprogram your remotes and keyless entry.
If this does not fix your problem, most likely your receiver is bad and may need to be replaced.
Hopefully this has helped you. Keep me posted!
CarrieSharee
Jun 24, 2011 | liftmaster 355LM Garage Door Receiver...
My 2004 hyundai has a check engine light on with a code p1520. I clear the code and it comes back on and my car goes into fail safe mode.
P1520 Generator Front Terminal Malfunction is what that code means. you need to fix that issue as clearing the code and not fixing it will just cause the check engine light to keep coming on.
i would suggest unhooking the battery. cleaning the terminals and hooking the battery up again... if you have an antitheft radio make sure you know the code and how to enter it before you unhook the battery.
Mar 04, 2011 | Hyundai Motor 2005 XG350
My uniden dect 6.0 cordless phone with digital light keep flashing but can't retrive the message how do i clear the light flashing
Feb 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Memorex Phone model MPH692-red light continues to blink
The light may be a "new call indication" or "message waiting" indication if you have voicemail service from the phone company. If you clear the caller id log or clear the voice message the light should go out. BUT, it will keep coming back on when a new call arrives! I have a similar phone and I just put a piece of tape that matches the color of the phone over the light.
Apr 21, 2010 | Lands Phones
Check engine light and cruise lights came on simultaneously.
Sound like the O2's heater circuit may not be working, that will set a code. I am not a big fan of univeral O2's, too many problems with bad connections and the check engine lights coming back on. You may need to use a OEM type sensor to keep the light off.
Jan 29, 2009 | 2006 Subaru Legacy
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
