How to fix audio problems ?
Tried testing speakers good. adjusted audio setting but nothing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 12 Answers
Try resetting it to factory settings
Posted on Dec 10, 2014
Subwoofer not working
The subwoofer is dependent on a sound amp powered by an external source whereby the speakers are powered by the line output from the sound source (like a computer speaker out jack). Powered Subwoofers controlled by a power amplifier require a power source such as an AC/DC source plugged into the house power. If the device is defective or a mismatch, the subwoofer will not function. Try a new power transformer and see if that fixes the problem. Other than that, if the power transformer is good, then the woofer could be defective.
Jan 13, 2014 | MA Audio MA5137 700 Watt 5.1 Home Theater...
I dont have sound audio
hi good day check first the audio settings in your pc might be in mute or need volume adjustment. then check the speaker if busted you can try another one just to isolate the problem where came from. now if still nothing sound audio come out in your pc check the sound card re install the driver if needed. hope this will help you thanks for consulting the fixya god bless.
Aug 21, 2011 | Computers & Internet
My speaker in good but theres no sound from the pc
hi check first the audio settings with in your pc. on your pc click the my computer then click the control panel now select audio devices and then click speaker setting it might be in mute or off just adjust the sound level. check also loose contact at audio out jack with your pc.now if still nothing audio come out try to re install the driver for your sound card.hope this may help good luck thanks.
Aug 07, 2011 | Computers & Internet
I need to disable the built in speakers. I can hear the white noise hum static. I want to hear nothing. i have excellent external speakers.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select this device (disable)
this may vary depending on which operating system you have
hope this helps
Apr 30, 2011 | Computers & Internet
Sony 60 in LCD edge LED TV: Hooked up new TV to a cable box - have HD picture but no sound. TV speakers say on. Makes sound when TV channel is changed (static). But nothing when input cable (via HDMI) is...
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Aug 12, 2010 | Sony XBR60LX900 60 in LED TV
No Sound
try accessing your tv settings menu and look for audio settings. usually there is an adjustment that you can make for external audio speakers such as when hooking up to a sound amplifier or internal audio that accesses your internal tv speakers.
Oct 03, 2009 | Apex Digital PF2020 20" TV
I can see and hear my contact but they cannot hear me I have tested all the audio and microphone tests and they check out fine
MIC SET-UP :- VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | Microsoft LifeCam VX-3000 Web Camera
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
