Question about Rohl Plumbing
How do I change the cartridges in a rohl 4719 bridge faucet
Need to change the hot and cold cartridges
    Problem Solver:
  • 11 Answers
The Escutcheon under the lever needs to be removed to access the cartridge. These turn counterclockwise to remove. Using a strap wrench or some other form of device to get the grip you need without damaging the finish is the answer to your question. Once this is removed, removing the cartridges are obvious and easy.
Posted on Dec 18, 2014
  • 171 Answers
SOURCE: rohl 3810 faucet nut not engaging threads
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
replace the nut holding down the cartridge, the threads of the nut do not
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 2692 Answers
SOURCE: hot and cold water trickles from faucet--seems nearly clogged.
The debre from turning off the valves comes through the lines and clogs up,usually the aireator,the screen at the end of the faucet. Take aireator off ,,colena and reassemble. If that does not work,disconnect the  lines at the shurtoff agaoun and look for hte obstructions for the aireator back to the shurtoffs.
Posted on Apr 06, 2009
  • 68 Answers
SOURCE: Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Posted on Apr 12, 2009
SOURCE: Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Posted on Aug 29, 2009
  • 234 Answers
SOURCE: I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
Posted on Jan 16, 2010
Rohl pull down faucet does not swivel but to one side
Improperly, maybe. Incorrectly, probably. Have the installer redo.
Jan 27, 2016 | Rohl Plumbing
Rohl single lever kitchen faucet sprayer is working but faucet has stopped. Cleaned out the cartridge area but water has stopped diverting back to faucet. Have used faucet for years but now having trouble...
Can you post a picture or reference the model of faucet you have, also it may be quicker to call Rohl directly as warranty may apply and they may cover cost of repair parts and send them to you at no cost. Rohl 714-557-1933
Jul 23, 2014 | Plumbing
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
www.rohlhome.com/warranty.aspx
Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Guide to Replacing Cartridge on Rohl R77V3
Look carefully at all the prongs and receiving slots in the body of the faucet into which the cartridge goes to insure proper match.
Mar 03, 2012 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Jan 16, 2010 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
The XX thing will not give any cold water! We replaced cartridge 2x - now what?
check to see if cut off to the fauset is on if this is not the problem make sure there is a cold and hot water supply to unit check and make sure cause i have made the mistake of runnig to cold water supplys to a faucet.
Nov 04, 2009 | Rohl 1005/8TCB Tuscan Brass Country Bath...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Rohl 3810 faucet nut not engaging threads
Hi murphygm,
but to no avail.
Thank you,
Oct 15, 2008 | Rohl Plumbing
Plumbing Logo
241 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
