Question about Thermador Refrigerators
My Ice maker is on the on sign and has not been making ice. MD
ON AND OF THE SWITCH, EMPTY AND CLEAND.
    New Friend:
  • 9 Answers
Change the water filter and check to see if there is screen where water goes in if so clear it
Posted on Dec 10, 2014
Ice maker does not work
Hello Jerry;
My name is Peter. I am a retired field service technician.
There are several different ice makers.
Provide you unit model number. This is on a label in the fresh food section on the liner door.
What is going on:
1.) Does ice maker fill with water?
2.) Does the ice maker make sounds.
3.) does the ice maker fill with water, freezes and then does not dump?
Need more information to help you Jerry.
Peter, Baltimore, MD
Nov 08, 2014 | Refrigerators
No sign of ice maker making ice
The water valve could be bad or the icemaker may be bad.
Oct 11, 2014 | Refrigerators
Ice Maker is making ice but at an extremely slow pace. The Ice Maker has been in the "On" position for approximately 48 hours and the pan is only 1/4 full.
HI,CHECK FOR UNIT TEMP FACTORY SETTING,CHECK FOR CLEAND CONDENSER COILS ,GOOD WATER FILTER, AND FOR A GOOD WATER PRESSURE ...
Jul 05, 2011 | Frigidaire IM501 FRIGIDAIRE IM501 ICE...
Ice maker over makes ice then ice cube tray cannot empty and new water comes in and overflows into ice bin. stop are does not seem to be low enough to cut off production.
WHEN THE UNIT GETS FULL YOU ARE GOING TO HAVE TO SHUT ICE MAKER OFF...
unfortunately there is no sensor to tell the ice maker to stop production so this will happen. sounds like the unit makes more ice that your family uses which normally would be a good thing... just shut the ice maker off until time to make some more and then switch back on ...
hope this helps you out.....
Jan 03, 2011 | LG LRSC26910 Side by Side Refrigerator
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Md#106.53542300; ice maker was making a clicking sound for a while and then the clicking stopped and the ice maker quit making ice
try a hard start electronic relay(it has a big capacitor to give it extra kick to start) clean both fins...oil fan motor
Aug 18, 2009 | Kenmore 53542 / 53544 Side by Side...
Ice maker not working andred light blinking
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Refrigerators
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
Fridgeidare freezer
how old is it ??? it only makes 8 ice cubes every 2.5 hrs or so when running correctly.some times 5 cubes depending on model. try reaching into the ice maker and feel the ice being made is the tray full or is there empty slots in the ice mold(asif not enough water). are the cubes hollow??( a sign of low water pressure)). have you replaed the waterfilterrecently (if applicable) old filterwill restrict water flow.
Mar 16, 2008 | Refrigerators
Open Questions:
Refrigerators Logo
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
ray gallant
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
