Question about Canon Office Equipment & Supplies
I try reset but eerm on function using error 002 displayed plz help
Canon e 510 eerm
comaire2004
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Posted on May 12, 2008
komguy
  • 2306 Answers
SOURCE: canon printer mp 510 error 5010
That is a purge system error, either you need a new purge assembly or there is a paper scrap caught in there stopping it. The purge unit is on the right where the printhead parks at shutdown and where the printhead is cleaned.
Posted on Aug 25, 2009
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
Cogz
  • 1326 Answers
SOURCE: My Canon np 6028 display
Theis code means that you have a problem with your fuser unit. It may be that one or both of the fuser lamps is not working. Or it could be a blown thermal fuse or thirmister.. Good Luck
Posted on Sep 05, 2010
Daniel S
  • 4323 Answers
SOURCE: my pixma canon MP 510
Hi
Error 5100 on canon is a Carriage Home Position Error. Try reseating the printer cartridges. If that doesn't help make sure there is no paper stopping the carriage from moving right to left. Try cleaning the plastic strip (encoder strip, behind the carriage) that runs the length of the carriage, it may be contaminated. Use alcohol and a swab (Q-tip) to clean. Before cleaning unplug it from the power supply. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
E000-001-002 please help solution regarding this code
This a fixing assembly tempature error. First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, ERR, Then Ok. Power down copier then wait a few seconds then power up again. If the error continues then the fixing film will have to be replaced.
Jun 21, 2011 | Canon imageRUNNER 4570 Copier
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Printer displays 510 error code. I need the local service center address
HI
Got this from usa canon.com website click here and type error code in the search box
a list of the error codes will be displayed and you can then click on the relevant one.
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
Jun 20, 2010 | Office Equipment & Supplies
How do i solve error code e 002-0101
This error indicates a problem with the fusing unit.
It may be a false code or a real problem.
You must enter the service mode in order to reset:
press the following sequence:
Reset key.
Additional Functions key (asterisk)
#2 and #8 at the same time
Additional Functions key (asterisk) again.
The display changes to service display.
Select the "Functions" tab
Highlight the "Clear" button and press OK
Highlight "ERROR" button and press OK.
Turn the machine off and on.
The machine will warm up.
If there is a real mulfunction, the code will reappear.
Sep 24, 2009 | Canon imageRUNNER C3220 Printer
E-840-002
Hello sir; The error code you display it's means " external heat roller sensor damage , replace it.
Aug 15, 2009 | Canon Office Equipment & Supplies
ERROR CODE 5010
Hi Friend,
kindly follows the below 2 steps
1.Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
2.The MP510 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need.
Regards,
Ayyasam
Jun 01, 2009 | Canon Office Equipment & Supplies
Error code E00012-002
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Feb 19, 2009 | Canon imageRUNNER 2200
Check printer 5B00
Hi guys,
Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber. Unfortunately you don't write the printer model so I cannot write reset procedure here.
Dec 25, 2008 | Office Equipment & Supplies
29 people viewed this question
old marine
old marine
