Question about Garden
Looking for a operating manual for a c950521350 snow blower
Homesite 52642 manual
have you tried putting your info into google?.
I have had a look but there is lots on there and I would not no what one to pick for you.
Nov 13, 2016 | Garden
Looking to purchase or download a owners-service manual(s) for Kubota F5210B snow blower
go google and type in -workshop manual for kubota f5210b snow blower --- and there will be a page for manuals or may be a pdf version down load
if there is a pdf version down load check the number of pages as it could be around 200 pages
contact your kubota service center as they may have a workshop manual on cd for sale
Dec 06, 2015 | Garden
The snow blower stopped going forward and backwards. It is a sears Craftsman and has been working excellent. It just stopped.
The most common cause of this is the drive belt is worn. In other cases the cable from the hand lever to the belt drive breaks or comes off.
To look at the belts and inspect the operation of the cable you remove the cover (usually plastic) in the middle of the snow thrower.
Your operator's manual will show you how to remove the cover and check/change the belts. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side). The model number looks like 247.123456.
The belt closest to the to the engine drives the transmission. This is the transmission drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't. The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears. They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Briggs & Stratton Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
Your Craftsman manual will show you step by step how to change th belt.
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
I have a craftsman snowblower that I believe is about a 1998-99 model. I need to know what type of oil it uses... If it does at all.
I can answer this for you if I have the model number of the snow blower. But, if the snow blower uses a 2 cycle motor it will use an oil/gas mix and no oil in the crankcase. If it is a 4 cycle motor it uses oil in the crankcase and none in the gas.
The easiest way to find what type of oil it uses is to look in the operators manual. To get the free manual go to managemylife.com and input your model number in the manuals tab.
Your model number is located on the machine and looks like 247.123456.
Dec 17, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I HAVE A DYNAMARK SNOW BLOWER MODEL # 53605400 HB3 WOULD LIKE ONERS MANUAL
You can download operators and service manuals directly from the Agrifab website by clicking on the provided link:
Downloadable Manuals
I trust this information proves useful.
Oct 06, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Looking for an installation manual
You can download operators and service manuals at the link included:
I trust this information proves beneficial.
Dec 06, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Snow througher diagnostics
Snow *Thrower
I recommend contacting your nearest authorized service center, or you can download operators and service manuals at the link included:
Jan 29, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
