Question about Tools & Hardware - Others
How do I get my nail guns to work in cold weather
Don't know what to do
    New Friend:
  • 7 Answers
Make sure you drain your tank daily.moisture accumulates in your nail gun and freezes.make to use the right oil in the gun.when not in use. Keep in warm place.
Posted on Dec 10, 2014
Testimonial: "I might have too thick of oil could that do it there was no water in the tank"
I have a bostitch MCN 150 strapshot that does not work in cold weather, under 50 degrees. Is there a fix for this?
Most likely worn orings in the trigger valve (# TVA14). Cold weather usually does not affect the gun, however using wrong oil would. Replace the trigger valve and /or try using power steering or brake fluid as lubricant for your gun during cold weather and regular nailer oil during warm weather as these other fluids may have a long term effect on the orings (cause them to swell slightly). You can test the other fluids for long term effect by placing an old oring in a cap full of oil for a week or so. I use two orings of the same size, one for control to compare against the one in the oil. No big deal. Also check for worn parts in the safety foot and /or worn trigger. If you have a single shot trigger (light color plastic) try using the bump fire trigger. Good luck.
Apr 17, 2013 | Stanley Bostitch Mcn150 Strapshot Metal...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
I inherited a Bostitch N805B uses 28 degree .113 and came with clipped head nails. Will it shoot full round head nails?
I could only find a Bostitch N80SB full round head nailer in their lineup so I hope that's what you have. No it will not fire full round had nails because they are stacked at a lower angle to accomidate for the full head and material used to hold the strips together. Senco does make a full round head nail that fits their clipped head nailers but it does not list the Bostitch nailers as one they will fit into so I don't know if they will work in your gun. The Senco part number for their three inch, full round head nails for clipped head guns is K527APBK.
Jan 31, 2012 | Tools & Hardware - Others
I took my arrow ET200 nail master apart to remove jammed nails. I need a diagram on how to put it back together
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
Jan 24, 2012 | Arrow ET200 Electric Brad Nail Gun
HOW TO USE A REMINGTON CONCRETE NAIL GUN
If you don't know how to use a nail gun ,you need to get instructions from a professional. In Calif. you must be licenced to use a power actuated gun.
Sep 14, 2011 | Remington Garden
Don't know how to load the nails in the gun
There are two ways dependent upon the gun model. Pull the charging handle back and insert the nail clip with the forward facing, leading edge POINT in first. Some guns allow you to put the nail clip(RACK) in the gun then pull back on the charging handle. BOOM your ready to shoot.
May 28, 2011 | Tools & Hardware - Others
I have a SCN40R gun that doesn't advance the nails in the coil part. What could be the problem. The part that is suppose to advance the next nail doesn't move.
The feed pawl is moved by a piston that extends from a cylinder on the lower side of the guide body. There are a couple seals inside the cylinder that if damaged will not hold enough air to activate the piston and advance the next nail. The two seals are Senco part number LB0828 & LB0845. Better yet get a Senco YK0369 repair kit and replace all of your o-rings, you'll have a like new gun for around $60.
Jan 06, 2011 | Senco Air Tools & Compressors
Having problems with the gun not pulling the next nail, the thickness of the wire between nails sticking in gun and then double shooting. using gun in new england, its cold we warm it first. any...
Nail feeder on this gun is both air and spring controlled. Air pressure retracts the feeder and a strong spring pushes the feeder back to front. Remove nails and leave side door open. Dry fire gun very rapidly against thick rubber pad and watch the feeder retract and return. It should move very rapidly all the way back and front again. If it appears to move slower than piston is moving then follow next step. Pull the feeder back manually with tip of screwdriver. It should be very hard to overcome spring. If spring feels strong then suspect feedpiston oring or air supply to feedpiston chamber is restricted with debris from inside of the gun housing or air is leaking where body of gun mates with lower nose. There is a small white oring that seals between body and nose base. Sometimes this oring will be over-compressed thus restricting air flow into feed chamber. Remove two allen screws at front of base to split body from base and reveal this oring. Parts are available at www.toolpartsdirect.com. Good holidays
Dec 25, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
Tools & Hardware - Others Logo
46 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
