Question about GE Refrigerators
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
I have checked for leaks on the inside and out, rotting food, cleaned the interior on both sides of the side by side with bleach and soap. I cleaned the door gaskets and ice dispenser. I even had a technician come and they did not find anything. However, he did remove the back cover and wiped away a lot of dust off the parts. The make and model is GE Monogram zfsb26dnd SS.
    Top Expert:
  • GE Master
  • 44,073 Answers
If your refrigerator is frost-free, check the drainage tray at the bottom, probably behind a removeable grille. You may find the tray is full of all kinds of disgusting stuff collected by drainage during defrost cycles. Remove the tray and clean it thoroughly. Reinstall the clean tray.
Posted on Dec 10, 2014
  • Mrs Parker Dec 11, 2014
    Thanks for your response. The tray was not removable. I used a wet vac to suction and blow out the dust. I used a turkey baster to put water with clorox in the tray. After letting that sit, I suctioned it out. I used pipe cleaners drenched with clorox to clean the curved drain pipe. To clean the front side of the condensor, I had to remove the grill and brush off what I could with my dryer brush. The odor is still there.
GE Monogram refrig. is freezing food in the deli fresh, fresh produce drawers and 1 shelf above. The temp is set at 37 but is actually 29 degrees. Ran diagnostics. Damper problem? Any advise?
as this is a self help fixing site we have no manuals here . but why don't you just adjust the temperature to a lower number and see what the temp goes to
Jan 27, 2017 | GE Refrigerators
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
The coil underneath the refrigerator, called the condenser coil, is probably blocked with dirt. This causes undue heat on that coil and the dirt stinks. The condenser coil must be cleaned thoroughly.
Dec 10, 2014 | GE Refrigerators
Ge monogram..the actual model is zfsb26dnd ss.. The temperature has been randomly fluctuating worse than ever. The freezer is now at 31! It has never been perfect. It used to only climb in temp when it...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | GE Monogram ZFSB26DRSS Stainless...
Need radiant trays & lava rock replacements for GE Monogram 24" grill model # ZGG24L20BSS Natural Gas.
The tray and lava-rock is available at most larger retail hardware stores. You may not find the exact tray for your model, just get one of equal size.
Jun 05, 2010 | GE Monogram ZGG24L20BSS Grill
Ge microwave spacesaver smells like burning wire researching the problem sounds like high voltage diode how do i get to the diode and check it
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
With the model number, we can offer more specific advice or an estimate.
But since FixYa does not notify us experts of follow-ups, you would need to post a new help request.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Bad odor from plastic tray underneath refer
Depending on the model the tray may or may not be removable.
Try removing the front grille located below the doors close to the floor, typically this will pull off with a little force on ends. The pan if accessible should be on the left or center. If it is not removable you may be able to put some cleaner into the pan from the front.
If it is not accessible from the front you will need to roll the frig out and remove the back panel once you unplug the power cord. The panel on the rear near the bottom may look like a piece of cardboard but is important to put back.
Apr 18, 2010 | Frigidaire FRT21H8 Top Freezer...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Handle is loose on GE Monogram Model# ZFSB27DAG SS. How do I get thehandle tightened up? No steps have been taken to fix problem. Stirwin
handle secured by 4 stainless stand offs on each door correct?, i would look closley at the underneath of the standoffs should be a screw to tighten/loosen. . actually lookin at diagram theses are comlete doorskins wrapped around the door itself you might need to remove teh screws on top and bottom ofr door skins and tighten from behind s/s skin
Mar 04, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
