Question about PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote
How do I delete pictures off the SD Card? I see the delete button on the remote, but I am unable to find a menu option to delete.
    Master:
  • 373 Answers
Better take it to your computer so you can more easily handle all the photo files at once.
Posted on Dec 10, 2014
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How do i delete all pictures off my camera
  1. Press the play button--which features a picture of a solid triangle in the middle of a rectangle--on the backside of the camera.
  2. Press the "menu" button to access the playback menu.
  3. Rotate the multi-selector dial to scroll the menu cursor to the "delete" option represented by a trash can.
  4. Scroll to the option "erase all images" and press the "OK" button on the backside of the camera.
  5. Scroll to the "yes" option on the confirmation dialogue and press the "OK" button on the backside of the camera. If a removable SD memory card is inside the camera, the camera will delete all of the photos on the card. If there is no SD memory card, the camera will delete all photographs in the internal memory.
If you need more help concerning your Nikon COOLPIX camera, I've posted an online manual of your camera below.
http://www.nikonusa.com/pdf/manuals/coolpix/S200_en.pdf
May 07, 2011 | Nikon COOLPIX S200 Digital Camera
How do I format the sd card in the DMC_ZS7
Welcome to FixYa.
To format the SD card, select [Format] from the [Setup] menu
To bring up the Menu option, press the Menu/Set button. Then select [Setup] and then select [FORMAT]. Then choose Yes to format the card.
Please note:
This requires a sufficiently charged battery, or an AC adaptor (optional) and DC coupler (optional). When
formatting the built-in memory, remove the cards.
(Only inserted card will be formatted if present; built-in memory will be formatted if no card is inserted.)
• Always format cards with this camera.
• All picture data including protected pictures will be deleted.
• Do not turn off power or perform other operations during formatting.
Thanks for using FixYa.
Feb 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
I have no instructions on how to operate. I need to clear the SD card as it is full.
You can usually find a delete option on the camera to delete single pictures or delete all. Typically found with the menu button on the camera. Some will have a tools menu and you can usually find the delete functions there.
The other option is to remove the card and delete with a computer and flash card reader.
Jan 03, 2011 | Cameras
What is "write protect" I am unable to delete pictures from my sd card like i have been before while n my ge A735 camera or by placing it in my computer when camera is in playback mode and i go to menu...
Hello. Remove your SD card and look carefully at the edges of it. you will see a little lock which prevents you from deleting any pictures. Just unlock it and reinsert it. Joe
Apr 18, 2010 | General Electric A735 Digital Camera
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
How do I delete pictures from the memory card on my Kodak M1063? Thanks.
The best way to delete all information on your memory card on Kodak M1063 is to format the memory card:
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button
Jan 22, 2010 | Kodak EASYSHARE M1063 Digital Camera
How can i erase the current pictures on my frames memory card to replace with other pictures?
Remove any SD card, turn on the frame, then press the "Exit" button 1 time on your remote. You will see the side menu flash, this indicates that you can now navigate up or down in that menu(Press enter on remote to activate the highlighted sub-menu) Press "Exit" again this puts you in the Media Memory menu, navigate to "Internal Memory" Press "Exit" one more time, this will allow you to navigate through photo's stored in the internal memory. Now if you press "Setup" on your remote it will bring up the copy/delete menu! navigate this menu with the up/down arrows on your remote to which ever option you prefer, press "Enter" to execute the highlighted command.
Don't forget to let me know if this helps anyone!
Dec 26, 2009 | SmartParts INC. digital frame. 7.0 in....
How do I tranfer pictures from Kodak easyshare cx7300 built-in memory to a SD card?
Hi there, welcome to FixYa. I can explain that for you.
1) Put your card in the camera and format the card.
2) Go into the menu and set the camera's image storage location to the internal memory.
Then do this:
1) Press the Review button.
2) Press the Menu button.
3) Scroll up or down to highlight Copy.
4) Press the Ok button.
5) Press up or down to highlight an option
5) ALL to move everything (pictures & video) to the other location (the card). - Picture or Video to move the current item to the card if you just want to move one thing at a time.
By the way. This will only COPY the images or videos to a card. They will still be in the camera's internal memory. If you want to delete them you have to follow the Delete images procedure.
To Delete:
2) Scroll Left or Right to find a picture.
3) Press Delete button
4) Scroll Up or Down to highlight an option.
The ALL option will delete everything.
5) Highlight Exit and Press the Ok button.
That will cover it. Thanks for coming to FixYa and feel free to rate my solution.
Rob
Mar 06, 2009 | Cameras
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Logo
93 people viewed this question
Top PANDIGITAL Photography Experts
LP
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
