No I am trying to return a drapery panel I ordered from amazon.com and need to return it
The pattern is a neutral leaf scroll design. it is a blackout drapery panel 84 inch
How do I return a faulty item to Amazon
That's a good question. Amazon will general accept a return within 90 days of purchase. First, log in to your Amazon account. In the uper right portion of the page you will see a button for "My Orders". Click it and you can either type the item name in the search box or scroll down to find the item in question. In the box containing your order you will find a few options. There you can select "return Item". Click on that and you will be promted to select the reason for your return. If you select the choice for defective item you will be prompted to print prepaid return label, At that time you will usually be prompted to select a refund or replacement.
Nov 29, 2017 | Cell Phones
I'm trying to figure out how to print a return label for a dress I purchased through Amazon from East of Maui Hawaiian Store.
If Amazon fulfilled this and you purchased with Amazon prime - you should be able to request the return and print the label directly from My Orders interface. If this was from an independent vendor on Amazon, you may need to contact the vendor and they will possibly send you the label via email. Otherwsie, you may be responsible for the return shipping. Either way - you can learn more from the orders interface.
https://www.amazon.com/gp/css/order-history?ie=UTF8&ref_=nav_nav_orders_first&
May 01, 2017 | Clothing
I don't have any shipping documents but i ordered it through Amazon
Oh, its' you with 'I need help with a return' :>)
Refer to your confirmation email and use the details in that. You can also log into Amazon and click Account and then Order History. This will give you the order number and product details and price.
Check out this information
Amazon.ca - Returns Centre
https://www.amazon.ca/returns
Been holding on to something past its return date? You can sell it online at Amazon.ca! To list a book, CD, cassette, DVD, video, or video game for sale, find its ...
Amazon.ca Help: About Our Returns Policies
https://www.amazon.ca/gp/help/customer/display.html?nodeId=915466 Our online Returns Centre will guide you through the return process--you can even print out a return shipping label. After packing your return, please send it ...
Amazon.ca Help: Return Items You Ordered
https://www.amazon.ca/gp/help/customer/display.html?nodeId=201515480 You can return many items sold on Amazon.ca. When you return an item, you may see different return options depending on the seller, item, or reason for return.
Amazon.com Help: Returns & Refunds
https://www.amazon.com/gp/help/customer/display.html/?nodeId=901888 Returns & Refunds ... Returns & Refunds. Exchange or Replace an Item ยท About ... Return a Textbook Rental. Return a ... Return Kindle Content. Return Kindle ...
Amazon Google Search
Apr 24, 2017 | Amazon Computers & Internet
Is it possible to order bricks
We designed and built a house in TN in 2000 and special ordered brick for it. We looked through some samples and chose brick that appeared to have subtle fossil and leaf patterns. The brick was delivered to the house site.
Jan 02, 2015 | Building Materials
Return items to amazon
How to Return Items Purchased on Amazon
1)Go to your amazon orders page
    2)Each order will be in a box
    3)Click the return items button on the right side
    4)Click the checkmark of the products you want to return
    5)Then select a reason
    6)Briefly explain the problem
    7)Click continue
    8)Click way to resolve problem
    9)Click continue
    10)Schedule a pickup date
    11)Change address if needed
    12)Click submit
Aug 27, 2014 | Amazon.com Kindle
What is a special order wedding gown?
A special order gown uses the designer's pattern but using your own specific measurements, to create a gown that fits perfectly. Once the basic gown is made, you then go in for fittings to make small adjustments and changes.
Feb 27, 2013 | Clothing
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
VERY IMPORTANT
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
http://static.tigerdirect.com/pdf/brother-IntelliFax-775-Manual.pdf
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Televison & Video Logo
Top Televison & Video Experts
