I have a coler ssc-21c what are the 6 pins on the back ,and from right to left what dose each one do.
    Brigadier General:
  • 3,400 Answers
MOORE DETAILS.
Posted on Dec 27, 2014
  • 73 Answers
Hi Give me fool name of the motherboard vendor
Posted on Dec 25, 2014
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
On the back of the radio on a 1994 dodge what pin in the back is the hot wire goes on`looking at the back if it lift to right
The connectors are slightly different depending on which radio system you have. The wiring schematics only say connector 1 and connector 2, so I can't tell you which is left and which is right. All the systems use the same pins for the hot wires, however. They are pin #6 and pin #7 in connector #1 They are (as you may have guessed by the numbers) right next to each other. Pin #6 is RED/WHITE and is hot only with the ignition switch in the ACCESSORY or RUN positions. It is protected by fuse # 12 in the Fuse and Relay Box (Under the left side of the dash). It is a 10 Amp fuse. Pin #7 is PINK and is hot at all times. It is protected by fuse #F2 in the Power Distribution Center. (In the engine compartment, left side) It is a 5 Amp fuse.
Mar 12, 2011 | 1994 Dodge Dakota Club Cab
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I need a wiring diagram for rj-11e.
rj11e pin lay out with turned over. brass pin facing you.release
pin to the bottom. 1 left to right to 6.
1 2 3 4 5 6
bk---red--green--yellow--clear (bare ground)--
that is it.
Aug 22, 2010 | Samsung Weather Resistant Security Camera...
No spark all ohmeter checks ok
4-pin upper left=blu/wht
upper right=yel/wht
bot left=blu
bot right=yel
6-pin upper left=yel/with blue stripe
upper right= green
mid= blank
mid= blank
bot left=blu/with yellow stripe
bot right=blk/wht
can you rate this thanks!
Apr 29, 2010 | 1987 Honda CBR 600 F(1)H
Don't print error scaner
have just managed to repair my Epson CX3200 thanks to the site! It took 24 hours of messing about but now it works perfectly again. It had the error light on and the display said certain items inside printer are beyond user life contact distributor. It has been a great machine for 3 years exactly and as it had been performing perfectly I was loathe to bin it. I followed the advice and hey presto! I have few tips to anyone attempting same.
1. Download from the site as recommended SSC Service Utility http://inkjetprinterhelp.us/
2. When taking off the scanner unit there is a smallish cover on the left hand side of the printer at the back; remove this and disconnect two ribbon cables, two cables with push pin conectors and a spade connector, 5 altogether.
3. Two screws hold down the hinges of the scanner unit remove and store carefully. Lift off scanner unit.
4. Take out four screws holing printer body on, long magnetic philips screwdriver needed. store screws lift off cover.
5. At back of printer are the three waste ink pads; use a spade end screw driver to lift out one at a time. They are about 5cm x 9cm and the bottom one is slightly different shape to other two.
6. Rinse them thoroughly with water and then squeeze out and dry. I used kitchen roll and then hair dryer.
7. Replace one at a time tucking in corner bits with screwdriver.
8. Replace body, scanner unit, wires and cover.
9. Connect up printer and switch on. Error light will come on again; don't dispair, this is what fooled me. Open SSC utility on desktop and then close; icon appears in lower right screen on application bar like printer icon. Right click and pop up menu appears; left click on "Protection Counter" and then "Reset Protection Counter".
10. Turn off printer and then switch back on again. Error light should go out and you can carry on.
Apr 17, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Mar 09, 2009 | Samsung Weather Resistant Security Camera...
What coler wire is what going to the trailer
is it a 4 pin flat or 7 pin circular?
most times you need to consult your owners manual about this, or a service guide
Feb 23, 2009 | 1999 Dodge Caravan
Im sittin here with the wiring harness for my 99 altima, and the wiring thing from the back of my pioneer deh p6700MP, i have no clue which ones to match with the other one?
Here's the manual for the Pioneer -->LINK<--.
This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
Radio Constant 12V+ Wire: Pink
Radio Switched 12V+ Wire: Blue
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Green
Radio Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Green/White
Front Speaker Size: 4′ x 6′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Brown
Left Front Speaker Wire (-): Black/Red
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Black/Yellow
Rear Speaker Size: 6 1/2′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Orange
Left Rear Speaker Wire (-): Black/Pink
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Black/White
THERE IS AN ALTERNATE WIRING COLOR CODE
THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
Large 10-Pin Connector:
Constant Hot (Memory or Clock) =RED wire pin8
Switched (Ignition) Hor = Blue wire pin4
Left Front Speaker + = Blue/white pin1
Left Front Speaker - = Blue/yellow pin5
Right Front Speaker + = Brown pin2
Right Front Speaker - = Brown/white pin6
The Smaller (6-pin) connector is only for the rear Speaker:
Left Rear + = Red pin5
Left Rear - = Green pin4
Right Rear + = Blue pin2
Right Rear - = Pink pin6
Regards
Philip
Jul 21, 2008 | Car Audio & Video
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
