Question about Kenmore Kitchen Appliances - Others
Have Kenmore Bread Maker model # 100.12934. Just bought it two days ago and went today to make bread. Machine will not stop the kneading process. I (even though I know it will screw the bread up) started over. Well even this second cycle the kneading process never stops. Other than taking it back (real close) what are my other options?
  • Matt DeBack
    Matt DeBack Dec 10, 2014
    Bryan, Thank you for your response. I think I did not frame my question accurately or with enough detail. The kneading paddle kept mixing the dough for 2 hours before I stopped the process. Bread had risen to the top of the bin but then receded when I put a stop to the paddle from going around and around.
    Master:
  • 373 Answers
Part of the kneading process is letting the dough rise. This takes hours, so be patient before giving up.
Posted on Dec 10, 2014
Testimonial: "Bryan, Thank you for your response. Appreciate it. But I think I did not frame my question well enough. The machine, for over two hours, did not stop the kneading paddle and go into the bake process. I actually did it twice, both with the same results. Dough rose to correct height in the pan but the paddle never stopped until I turned the machine off. Gonna give it a 3rd shot in a couple of hours and see what happens."
  • Bryan Smith Dec 10, 2014
    Hi Matt, you are probably facing a problem that will require a warranty service on it. Sorry.
How to use machine sunbeam oster bread making machine model 4811
go google and type in--operators manual for sunbeam bread maker model 4811-- and if there is a manual available in pdf version down load it
just be aware that with these machines there is a period in the program where after the needing process, it stops for a period to allow the dough to rise before it goes to the cook process
most machines work on the same principle so if you can not find a sunbeam manual see what else is available and check it out
Feb 21, 2016 | Sunbeam Oster 1.5 To 1 Lb Bread Maker...
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
Can't get knead bar on West Bend automatic bread maker
Was the bar ever installed on your bread maker? Is this a replacement knead bar (paddle)?
Jan 01, 2013 | West Bend Bread Maker Machine Knead Bar...
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
The paddle for my Breadman BK1060BC has been coming off during kneading. Today, I saw some grey residue in the dough. Is the problem with the paddle, pan or both? Thanks.
I just purchased this 2 days ago and started to use it. I noticed the bread pan would wobble and was noisy during the kneading cycle. On the second use the paddle came off during the kneading cycle. Being a service technician all my life, I started to analyze the problem. I was previously surprised how loose the bread pan fitted into the bread maker and suspected there should be something to support the pan and hold it in place. I could not see anything obvious, but after looking carefully I noticed spring clips on the bottom of the bread pan, and also mating spring clips in the bottom of the bread maker. If I pushed the bread pan down fairly hard into the bread maker the bread pan would snap firmly in place. This stopped the wobbling during the kneading cycle and the paddle coming off. I could not find anywhere in the manual where it explained the bread pan must be pushed firmly down into place until it snaps in. The manufacturer should explain this to their customers on their website.
Apr 23, 2011 | Breadman TR2500BC Bread Maker
Toastmastter breadmachine model 1186. I used it two days ago, worked fine. Today the drive belt will not turn. It makes a small clicking noise. Can you oil the shaft or are the bearing gone?
Hi, Take the bread pan out of the machine and see if it still makes the noise when you start a kneading cycle. If it still makes the noise then the belt may be loose or a gear has chipped. If everything is normal then it could be the bread pan. There is a sealed bearing on the bottom of it and when that breaks or freezes then the paddle won't turn and it's time for a new bread pan Be sure to unplug the machine when checking belts. They are located in the base of the machine. Hank
Jan 24, 2011 | Toastmaster 1183N Bread Maker
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
Used the breadman successfully 6 days ago. today; nothing happens. Window states "knead" but nothing happens at all.
Are you making a different kind of bread than you did the first time?. If so some machine programs have a delay before they start kneading such as the whole wheat cycle. Also some machines delay the kneading process while they warm up the ingredients. If it is colder where you live now than itw was 6 days ago that could be a factor.
Oct 12, 2010 | Breadman TR845 Bread Maker
Bread is overly dry and coarse textured
You're doing everything great with your ingredients. Listen to your machine or watch it. Stop it before the bread is in the rise cycle and restart it after the kneading cycle.Try running the knead cycle two times, then the rest of the baking cycle. If the bread is still too hard try using the kneading cycle three times. This process is trial and error, but I firmly believe this will solve your problem as it did mine.
Dec 10, 2008 | Sunbeam 5891 Bread Maker
Welbilt bread machine kneading blade stuck
I have the same problem. I have used Liquid Wrench and other products to no avail. *sadness* What a shame that I have a working machine but the pan is a goner.
Jun 10, 2008 | Breadman TR888 Corner Bakery Bread Maker
Kitchen Appliances - Others Logo
100 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
