How do I get the record player to have sound I got it to turn on but when I put the needle on the record there is no sound
    Master:
  • 373 Answers
Do you have the turn table plugged into a receiver or amplifier? Unless it is self-amplifying, that's what you need to do.
Posted on Dec 10, 2014
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
I have a rowe ami R-83 Disco 200. It was working fine until the record got hung up on the needle cartege. When I tried to free it up the arm bounced up but seemed fine. Put the needle down on the record...
I know little about Jukeboxes but I do know how delicate the cartridge is and the connecting wires. Considering the sound stopped after the arm bounced it would be a very good idea to check the cartridge and the connecting wires before you do anything else.
Oct 07, 2017 | Audio Players & Recorders
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
I have a Panasonic pll multiplex circuit and when I put a record on it skips a lot. I have another record player at my other house and it has an adjustable weight on it, and I am thinking that that's...
Most likely needs a new needle. Try needlelady.com or needledoctor.com Modern record players usually track at 2 to 4 grams of pressure. Thats about as much as a penny weighs maybe. Putting more pressure on it, will only cause it to destroy your records or sound bad. Weight adjustment is usually a very fine spring or counterweight that adjusts on the tonearm. Linear units use optical sensors to keep the tonearm aligned, but use traditional counterweights to control force. You need a gram scale made for phonos to properly adjust it. Radioshack USED to sell them 30 years ago, but most times you can just use a guess if the needle only slightly deflects when placed onm the record your usually good. If it's simply jumping and sliding across the record then the needle is shot. Even diamonds don't last forever,. as they are synthetically produced.
Jun 19, 2011 | Audio Players & Recorders
I have a vintage magnavox record player and need a replacement needle... how do i go about that?
Try Phanstill and Garage-A-Records to start.
Also Needle Doctor is on line as well! Put record
needles in a search box and check em all out!
Apr 14, 2010 | Audio Players & Recorders
WHAT IS THE STYLUS NEEDLE MODEL # FOR A RCA SS4000 RECORD PLAYER
Your source for all your antique radio, record player, turntable and phonograph needs!
Record Player Needles
Welcome to our record player needles and turntable stylus page! We hope you find this page to be very friendly and useful in locating a replacement record player needle or stylus for your phonograph. Use the picture charts of the record needles, and the information request form to help you identify which record player needle or stylus you need.
When it comes to stocking needles, we carry and stock more than just the "top brands", "most often needed" or "most popular" like other places you'll find on the web. Our inventory is very extensive and broad. Ranging from sophisticated high end types to plain straight steel needles for antique crank or wind up models.
Aug 31, 2009 | RCA Audio Players & Recorders
No sound coming from turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Jan 29, 2009 | Crosley CR248 Turntable
The record player skips
Hi There,
From your description it sounds like there is insufficient weight on the needle end of the pick up arm.
The pickup arm is very delicate in its balance at the "rear arm end" fulcrum.
This weight is adjustable to allow the needle to press on the music track to an exact pressure and it is adjustable so that this pressure does not damage the music track.
There should be a wheel type thingy at the rear end of the pickup arm.
This wheel is usually marked in Grams, and to make the needle end heavier to stop "skipping' you turn the wheel to wards the + sign.
This + sign means more weight on the needle.
There also should be a - sign, and the wheel, when turned in that direction, the weight on the needle is reduced.
You need to be aware that a needle really needs to exist in the cartridge as they can be broken off very easily and if there is no needle present there, then there is no way you will get any music from the turntable.
So check there really is a needle there...use a magnifying glass to see....
If thats OK then place the needle end of the pickup arm on to the record surface and turn the weight wheel until the needle just lifts from the record surtface.
Now that this stage has been received turn the weight wheel in the reverse direction by around 5-7 grams in the heavy + direction.
The needle should now be resting on the records surface and not lifting at all.
It should play like this,,,BUT please ensure the record player is on a perfectly flat surface the
needle wont work on any incline at all...
If you turn the amp on in the phono switch position and carefully hold the needle over the record and touch the needle with your finger you should get a scratchy sound from the speakers.....
This is a basic test to ensure the amplifier and all the wiring is in place and doing its job..
Im Sorry you had a run around from the repair company but some of them are not interested in repair work any more they just want to sell new hardware...
It pays to ask if they are Pepared to repair stuff for you , then get a commitment of a reasonable repair date and time in writing.
If this date and time is exceeded then you dont have to pay for the repairs do you??
As they have missed the service level agreement you had with them for the reapir date and time..
Hope this helps
From
YUBEUT..
Aug 13, 2008 | Teac GF-350 CD Shelf System
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Record Player won't spin
it helped enough. it gave us an idea of what was wrong. thank you. :-)
Jun 17, 2008 | Crosley CELEBRITY ENTERTAINMENT CENTER...
56 people viewed this question
 Grubhead
Grubhead
