Question about Zanussi Washing Machines
I have a Zanussi 1600 jet system washing machine and it's not draining its not doing anything can some1 help :(
I have tried to switch it on and off and checked all the pipes and the door nothing seams to work please help
    New Friend:
  • 87 Answers
Disconnect from power source for 5 minutes then reconnect and try.
Posted on Dec 10, 2014
I have a zanussi jet system 1600 and it's not allowing us to do a wash,we start the wash and it shows as 1.40 mins till complete then it jumps to 3 mins and stops,it's leaving all are clothes soaking and...
i guess its machine pcb error. take out front pcb and dry it well and reconnect to washing machine. still its not working you have to replace 8000 mhz xtal in control pcb.
Jun 05, 2014 | Washing Machines
Zanussi jet stream 1600 door locked
SOUNDS LIKE THE LATCH IS NOT WORKING AS IT SHOUD. I WOULD START BY REPLACING IT FIRST.
May 23, 2014 | Zanussi IZ161S Front Load Washer
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
No hot water in my washing machine
heater thermostat need replacing at worse you may need a new pcb .call an expert
Feb 11, 2010 | Washing Machines
Zanussi Jet Stream 1600 is displaying E10 as it has started its cycle to wash. Can you tell me what this means please?
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
Jan 10, 2010 | Zanussi IZ161S Front Load Washer
Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Feb 17, 2008 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
