Question about Transmission & Drivetrain for Dodge Ram 1500
I replaced my tranny,in my 1996 dodge ram 2500 7he transmission wont downshift in to first and overdrive isnt working.
Shifting problems
    Master:
  • 755 Answers
See if you have a vacuum leat on you modulator or ck to see if it is clogged , I do belive they still had them at the date ,
Posted on Dec 10, 2014
2000 ply. neon wont shift into overdrive
Plymouth transmission wont shift into overdrive Questions ...
www.fixya.com > Forum > Tags > transmission wont shift into overdrive
Plymouth transmission wont shift into overdrive related problems. Ask your Plymouth transmission wont shift into ... My 2000 plymouth neon is stuck in park.
Dodge Neon Questions - my neon will not go into overdrive ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusSep 14, 2012 - my neon will not go into overdrive, it stays at 3500 rpms on highways - my neon does not ... 2003 Dodge Neon won't shift out of park 5 answers.
part2 replace the shift solenoid and speed switches in a ...
? 7:15
https://www.youtube.com/watch?v=2ETvtt8fcr4
Sep 10, 2009 - Uploaded by Sean Conley
Dodge Automatic Transmission Removal - Duration: 11:05. ...Dodge Neon Crushed By Mud Trucks ...
Jan 25, 2016 | Cars & Trucks
Transmission
You need to replace the internal solenoids. Not a hard job. Drop the pan, remove the PWM solenoid, and shift solenoids. PWM is causing this issue. New solenoids will cure it. Kit on eBay is $255. https://www.youtube.com/watch?v=yOABDeJQrAE&vl=en https://www.ebay.com/itm/Ram-45RFE-545RFE-68RFE-Solenoid-Assembly-2004-Up-Dodge-Chrysler-Jeep-Mopar/351629865164?fits=Year%3A2005%7CMake%3ADodge%7CModel%3ARam+1500&epid=1853258599&hash=item51dec5f0cc:g:BI4AAOSwjDZYZrmf&vxp=mtr
Dec 07, 2017 | 2004 Dodge Ram 1500
Will a 1998 transmission fit into a 1996 dodge ram 1500
will 1996 dodge ram 15oo tranny work in a 1998 dodge ram
Apr 08, 2012 | Dodge Ram 1500 Cars & Trucks
1996 Dodge ram 2500 4x4 5.9 cummins Shifts in and out of overdrive in cold weather at lower speeds.
This mainly is caused by transmission fluid level changes. Measure it when its at running temperature and in park. Add if necessary (most likely the cause)
Jan 06, 2011 | 1996 Dodge Ram
When driving down the road in overdrive the van will downshift automatically and not shift back into overdrive on its own. Is there a sensor to check?
only internal transmission parts and solonoids that your average joe should never attempt to pull apart. ive been a mechanic for 10 years, and i wont go near an automatic transmission! they are evil! it might just need a fluid and filter change, and it might need a rebuild...only a transmission shop can diagnose those problems, and those are the only places i would even let near my transmission! todays trans. are all electronically controlled via an ECM (engine control module) which can also be having problems. it's impossible to diagnose correctly without looking inside the transmission, so id take it to the closest tranny shop and have them take a look. hope this helps.
Apr 28, 2010 | 1996 Ford Windstar
1997 dodge ram 1500 (360) transmission.
My 95 Cummins Dodge had the same problem and adding "Lucas Transmissiion Fix" cured it completely and permanently.
Thier claim is as follows:
Lucas Transmission Fix is a non-solvent formulas that stops slip, hesitation and rough shifting in worn transmissions and completely eliminates most seal leaks. Use in any transmission for preventative maintenance.Use also in light duty manual transmissions to increase shifting ease and transmission life.
Key Benefits
  • Contains no solvents
  • Lowers operating temperatures and stops foaming
  • Can be added to existing fluid without draining any out
  • Effective in an extremely high percentage of cases
Jan 11, 2010 | 1997 Dodge Ram 1500 Club Cab
1996 dodge ram 2500 auto transmission not shifting properly
Well, first do the service. Pull the pan down and look for metal shavings. If there is metal shavings your in for a transmission. If not, you may have a problem with one of the transmissions shift solenoids located near the valve body.
P.S. The Duramax has the Allison 1000 transmission not the dodge cummins and they are one of the best trannys on the market.
Oct 29, 2009 | 1996 Dodge Ram
Dodge Ram Transmission
You need to get your tranny rebuilt. The motor that is already in your truck is set up for that Tranny so i wouldnt change it at all as it would cost alot more then you need to spend to do it. . I also would go to Mr.Transmission as they do great work on trannys.
Apr 04, 2009 | 1996 Dodge Ram
Shifting Problem Auto Tranny
You are going to need the transmission rebuilt.
Jul 06, 2017 | 1994 Volkswagen Passat
Transmission does not always shift into overdrive
Governor pressure sensor or solenoid is going bad. To replace them drop the tranny pan, remove the filter , and the parts are pretty ez to get to. These aren't cheep thou, but replace them as a set. Parts will probly run about $200.
Jan 19, 2009 | 1999 Dodge Ram
Vehicle Parts & Accessories Logo
115 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
