Question about Jura Capresso Impressa F7 Espresso Machine
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Tried a paper clip, better but still drips slowly from one side.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Posted on Dec 10, 2014
While decalcifying the water comes out of the frother in intervals as it should but it does not come out of the spouts.
I have 3 different coffee machines and all 3 are descaling like you said using only the froter so that is normal .... Unless you misstyped the question
Sep 30, 2015 | Jura Capresso Impressa F7 Espresso Machine
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
How do you actually remove the spout on a Jura E8 to clean clog?
GENTLY GENTLY GENTLY
There are two parts: You will see the top part is fixed - it does not move. Remove it first, placing fingers behind the top of the piece, and gently it toward you. It will pop loose toward you - but not off. To remove completely, simple move the top half straight up, and it will release completely.
The bottom part of the spout is trickier, but equally easy once you know how it is fastened. Exam the bottom half. See how it is fastened by sliding on rails. Facing this piece, gently push leftward on the right side of the spout. The spout is flexible, and it will bow outward enough that the right side will come off its rail, enabling you to gently pull that side out. The left side will then come off as well.
Now you can clean out all the nasty.
Reverse these steps to put it back together.
Nov 08, 2012 | Capresso Jura-13187 Impressa E8...
Not dripping coffee on one side
That hole might be blocked, Try removing the spout and checking for obstructions. It is possible that coffee oils have clogged that side of the spout.
Dec 17, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
The coffee started coming out the brew spouts to the right and left and some coffee comes out in the center. i have cleaned and descaled the machine but that has not helped
I had this same problem and called Jura Capresso. They had me straighten out a paper clip and stick it up each spout as far as I could and jiggle it around (after bringing the panel with the spouts down as far as possible) Then they said to **** the panel containing the spouts up and down several times and then press the rinse button. Repeat this process several times. That did the trick for me. They said sometimes the spouts get clogged and just need to be cleared.
Nov 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
Jun 11, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso Impressa F7 Espresso Machine Logo
534 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
