Question about Proscan Televison & Video
My proscan tv has sound but no picture...can someone help me?
Unplugging and reset does nothing...can someone help me?
  • Proscan Master
  • 1,249 Answers
May have a bad backlight.
Posted on Dec 10, 2014
Proscan tv no sound
make sure speaker is on check menu settings but ti may need reseting go to www.proscanvideo.com for reset info.
Aug 13, 2014 | Proscan 19LA25Q 19 in. LCD Television
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
Jan 16, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 26L30QD picture and sound went off
You need to take this unit in for servicing for failed components.You can contact PROSCAN at this website.www.oncorpus.com.Go to the customer support section and ask them where you can take you unit for servicing. You can also call their customer support telephone number at. 1-888-977-6722. I hope this information helps you with your problem.
Feb 24, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Want to re-set to default setting on ProScan 1998 model PS27600
my tv after 10 min be on my pic start to dark slowly
Dec 27, 2008 | Proscan PS27600 27" TV
Proscan will not turn on
i had the same issues.. i took the TV into a repair shop and they replaced a peice for $40.00 (Canadian)
Dec 01, 2007 | Proscan PS27600 27" TV
Proscan s56700
call tech ...suggest checking horizontal drive.
Nov 12, 2007 | Proscan PS56700 56" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
