Question about Belling Dishwashers
Hi I have a belling dishwasher IDW604 and all of the buttons seem to be working except for the programme on which does not light up? Any advice? Thanks
SOURCE: My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
I had the same problem today - machine is two years old - cannot select a program - door does not close properly - the machine should bleep at you when the door opens or closes.
Problem is the catch - its has a powerful spring on the catch which in time distorts the two plastic bearings each side of the catch which then stops the door open switch working.
The fix is simple - new catch mechanism available from :-
http://www.espares.co.uk/part/dishwashers/belling/p/1083/154/0/0/551313/door-catch-assembly.html
Stock Number: ES551313
Price £11.49 Regards  - - - - - - Alan.....
Posted on Jan 31, 2009
  • 7 Answers
SOURCE: belling dishwasher IDW604
there is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
Posted on Aug 01, 2009
  • 7 Answers
SOURCE: bELLING IDW604
i have just fixed my e4 code problem
take off salt cover and remove all water with tea towel or dish cloth you must make sure all water is out switch off at wall then back on if still e4 reapeat getting water out my washer is cleaning as i type
SOURCE: belling IDW604
I found the solution myself. On the bottom plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to tilt the machine and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.
Posted on Apr 05, 2010
SOURCE: belling dishwasher IDW604 error code E4 on control
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Posted on Apr 19, 2010
I have a belling IDW604 integrated dishwasher which is not heating the water
An open element will have voltage present and still not operate. Use an ohm meter to test it.
Dec 21, 2015 | Belling Dishwashers
Belling IDW604 wont heat water
Check heater for continuity, thermostat and control timer
May 09, 2012 | Belling 24 in. IDW603 Built-in Dishwasher
E4 is displayed on my belling idw604 dishwasher and it won't operate
unplug machine. remove right hand side panel. check if water has collected in the bottom tray, if so soak up with cloth or kitchen roll until all water has been removed. switch on power and machine should have reser
Feb 07, 2011 | Belling Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Mar 05, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Belling dishwasher IDW604
Dec 21, 2007 | Belling 24 in. IDW603 Built-in Dishwasher
Instruction book
need the manual for the belling idw604 dishwasher
Jul 04, 2007 | Belling 24 in. IDW602 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Jeff Hogancamp
Jeff Hogancamp
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
