Question about Hoover Vacuums
My Hetty Hoover has no suction, but when I take the filter out it has suction Please help!
I have checked the hose for blockage.
    Problem Solver:
  • 7 Answers
Throw away your old filter if it is not cleanable. Only clean it if it is a washable filter. If not, buy a new one
Posted on Dec 10, 2014
My vax pet Hoover has lost its suction I've emptied it there's no blockages and Iv cleaned the filter
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction.
Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Jan 09, 2016 | Hoover Vacuums
My carpet shampooer will not **** the water back up. It is a Hoover Steamvac Deluxe 1600.
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
Jun 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vax c90 p 2 b 200wI have cleaned filters but hoover/suction keeps cutting in and out?Can you help ?
check for a partial blockage in the wand/ hose ( rag-ball--hair ball ) Check that the hose is not collapsing at past kinks.
Jun 11, 2013 | Vacuums
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
No sucking
if you have no suction - then the problem could be a dirty filter or a blocked suction hose. clean the filter and check the hose from top to bottom for blockage. if all is clean and clear and you still dont have suction then the problem could be a bad vacume suction motor.
c...
Feb 02, 2011 | Hoover U5175-900 Fold Away Bagless Upright...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Nov 02, 2008 | Hoover Vacuums
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
63 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
