Question about Philips Norelco BEARDTRIMMER Series 3000 Beard and Stubble Trimmer
Is it possible to modify a Norelco T-3000 trimmer for corded operation only? The battery in mine is kaput, and I do know how to solder, but I wish I could bypass the cordless operation entirely, if that is an option.
I need to change the battery in a norelco 7864 xl, how to do it?
You will find the correct battery type for model 7864XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. There are two metal clips that must be unhooked for better access. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Mar 13, 2011 | Norelco Health & Beauty
Will not charge.
Batteries need replaced. You will find the correct battery type for model 8883XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 04, 2011 | Norelco 8883 XL Electric Shaver
How to replace battery that soldered.
You will find the correct batteries for model 5885XL at shaveroutlet.com. See link below
To open shaver, remove two screws on the back. You will have to slide up trimmer to access the second screw. Remove back cover. Remove snap in plastic clip that obstructs your access to the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Jan 17, 2011 | Norelco Reflex Shaver 5885XL Electric...
I NEED HELP REPLACING THE NI-CAD BATTERIES ON MY SPECTRA 8865 XL
You will find the correct battery type for model 8865XL at shaveroutlet.com. See link below.
Jan 12, 2011 | Norelco Health & Beauty
How do I remove the batteries from a Norelco 4605x razor ?
Remove the 4 screws on the back to take off the back cover. You will have to extend the trimmer to access 2 of the screws. You can then unsolder the batteries from the circuit board.
If you are replacing the batteries, for easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find replacement batteries for model at shaveroutlet.com. See link below
How do I replace the batteries on my Norelco Spectra 8845XL shaver? I read somewhere that they need to be soldered on. That's not a problem, just want to make sure I do it correctly. Also, where can I...
You will find the correct battery type for model 7865XL at shaveroutlet.com. See link below.
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 30, 2010 | Norelco Spectra 8845 XL Electric Shaver
I have a Norelco 8865xl. It needs new batteries. How do I replace them?
Nov 29, 2010 | Norelco Health & Beauty
How do I change the batteries in my 6885XL razor
You will find the correct battery pack for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Remove the two screws on the back to take off the back cover. One of the screws is hidden by the trimmer so you must extend the trimmer to see it. Once back is removed, remove the metal clip at the bottom end of the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Soldering is required to replace the battery pack. If you are not capable of soldering in the new batteries, you may want to consider buying the item below instead for easy installation
http://shaveroutlet.com/philips-norelco-7886xl-quadra-shaver-lower-unit-part.html
Aug 28, 2010 | Norelco Quadra 6885 XL Electric Shaver
How are the batteries replaced on my norelco 7865xl
You will find replacement batteries for model 7865XL at shaveroutlet.com. See link below
To open shaver, remove the two screws on the back. Lift off back cover. Then remove the two metal clips inside to get access to the battery pack. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Aug 17, 2010 | Remington HC-600 Hair Trimmer
How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Jul 25, 2009 | Norelco Health & Beauty
Philips Norelco BEARDTRIMMER Series 3000 Beard and Stubble Trimmer Logo
50 people viewed this question
Top Philips Norelco Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Philips Norelco Health and Beauty Expert? Answer questions, earn points and help others
