Question about Ovens
Wiring information for a zanussi hob. - Ovens
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
Zanussi hob can't turn off full power on one ring
the regulator is faulty you will have to fit a new one fairly easy task let me know if you want more help
Apr 17, 2012 | Zanussi Ovens
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
Zanussi zbf360 the glass on the top (HOOB)has
It depends on the make and model, that number you quoted is for your slot in oven,the hob is a seperate unit.They could cost more than the hob is worth but if you get the model number and relog the question maybe we can help.
Hope this helped.
Apr 28, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
I need replacement control knobs for my hob-can
In your browser bar type in-------WWW.SERVICEFORCE.CO.UK.
Follow the links in the drop down menu, and you should be able to order the parts you require.
Thanks.
Nov 07, 2009 | Zanussi ZBF360 Electric Single Oven
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
I can't get my Zanussi oven to work
Make sure timer is set to manual. and not on auto
Nov 19, 2008 | Zanussi ZBF260 Electric Single Oven
Removal of hot plate hob
usually you have to take the side panels off and hobtop is secured by screws to frame
Sep 24, 2008 | Ovens
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
