Question about Home
Just fitted a new gebrit twinco1 but the seal is not dropping back after the flush, it is stuck and will not drop.
Replaced it tried to adjust it but no instructions. I reduced the water flow.
    Top Expert:
  • Home Master
  • 45,018 Answers
A binding flush lever or insufficient slack in the flapper chain can prevent the flapper from reseating.
Posted on Dec 10, 2014
How do I adjust the flapper on the Fluidmaster 400AK Complete Toilet Tank Repair Kit For 1.6 GPF?
I struggled myself for a while looking at many online videos, replaced the flapper and the toilet still flushed on it's own! I noticed that the flapper chain got often stuck when the flapper lowered down, which caused water still running out and than I came up with my own idea; there is a white plastic fastener inside the water tank for the flush handle outside, that got apparently loose in time and can be even fastened manually, no tool needed! This fixed my problem! I haven't seen this tip anywhere, so I wanted to share it.
Mar 31, 2015 | Home
My toilet has a Geberit Twico 2 Flush Valve system.When I flush, one of the two small white plungers does not drop back down in position and the toilet will not refill.I have replaced the complete valve...
The best way to break up a blockage is by repeated back-and-forth movement of water, which happens when you push the sealed plunger down and then pull it back up again.
For more: Pressure Washerify
Mar 09, 2015 | Home
95 legacy awd Leaking transmission fluid out of the rear transfer case
If you have the space drop the drive line . You should have a tranny shaft poking out of the housing and the seal should be right at the back. 2 ways you can go. Get a good heavy screwdriver and lever out the seal or drill a small hole and with a slide hammer pull ot the seal. To fit the new seal use a piece of pipe That has the same dia as the outside of the seal tap the new seal in keeping it square to the hole. Tap in till level with edge of case. Check oil level and replace any lost oil as some will run out when you drop the drive line
Feb 22, 2013 | Cars & Trucks
The adjuster on the upper brke lever is leaking brake fluid ?
its the master cylinder seals leaking fit new seals or a new cylinder
Jun 13, 2010 | 2004 BMW R 1150 RT (ABS)
Is it good to flush a transmission after 220,000 miles?
NO it's not good, just give the transmission a normal transmission fluid and filter change. Flushing the transmission fluid may loosen up any thing that is keeping the O rings and seals from leaking and flushing out the transmission may cause it the fail much sooner then expected. My transmission on my 96 jimmy has over 365,000 miles and still going strong. You may want to replace the boost valve to ensure your getting the proper transmission line pressure, as the transmission get's older, the boost valve weakens causing the line pressure to drop. As the line pressure drops, the transmission starts to slip wearing out your clutch packs. I replace mine every service and the boost valve is not that expensive and can be replaced when the transmission pan is dropped. Good luck and hope this helps answer your question.
Feb 22, 2010 | Chevrolet Blazer Cars & Trucks
Oil leak at rear of gearbox it is a new exchange just fitted I also replaced the slip yoke and uni joint and fitted the genuine seal. toyota hilux with w58 5 speed
well, after all that, it should not leak a drop. if the yoke is new, then either the seal is bad/damaged or the bushing has too much play, allowing the yoke to "wobble" and the seal is unable to contain the oil. another thing to verify is that the vent is open and not plugged.
Oct 01, 2009 | 1997 Toyota Tacoma
An old eljer toilet with the drop ball and brass guides. I cannot get the ball to seal well. What can it be?
I think I have a similar toilet--I found at Lowes a new "drop ball" that seals the hole in the tank. You're drop ball might be disintegrating from the hard water in the tank. Take the tank cover off and shut off the water before flushing the toilet. Once it's flushed pull up the drop ball. Feel if it's still solid or not. It is easily removed by unscrewing it from the rest of the assembly connecting to the flushing handle. Unfortunately for me, the one they had at Lowes was slightly different in shape than the one I had, so I had to return it and deal with the older one. good luck!
Sep 22, 2009 | Eljer Home
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Aug 01, 2009 | American Standard Traditional Champion4...
Home Logo
47 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
