Question about Home
What is the meaning of nothing more by the alternate routes
  • 1,253 Answers
There is only one route
Posted on Dec 10, 2014
What is the belt routing for 5.4 w/o ac? my truck has ac but compressor locked up. can I just by-pass the ac?
yes a shorter belt will be ok . mostly the alternator can be used for adjustment. you will have to measure the length with a cord and get a belt to match.
Nov 28, 2014 | AC Cars & Trucks
I NEED A DIAGRAM FOR THE ROUTING OF AN ALTERNATOR BELT ON A 1.4 OHV SKODA FABIA WITH AIR CON PLEASE
The alternator belt routing diagram for a 1.4 OHV Skoda Fabia with A/C:
AC = Air Conditioning (A/C)
CS = Crankshaft
Gen = Generator (Alternator)
G = Guide pulley
T = Tensioner
WP = Water Pump
Please do rate my response. Thanks!
Sep 01, 2011 | Volkswagen Polo Cars & Trucks
WHEN IN A TRAFFIC JAM, HOW DO I FIND AN ALTERNATIVE ROUTE?
With the route showing on your satnav, press MENU and then DETOUR. This should take you around the traffic jam. Alternatively you could just turn off, drive a distance from the traffic jam and let the satnav update your route to get you back on track. I hope this solves your problem.
May 24, 2011 | Garmin (010-00583-00) for nuvi 750/760/770
How do you get the alternator out of a 2003 Focus SE, 16V Zetec DOHC?
Disconnect battery ground cable
Remove the ground wire (black) from the alternator
Disconnect the positive wire (red wire held on by a retaining nut) from the back of the alternator
Now disconnect the wire harness from the alternator
Remove the drive belt
NOTE: Some models use a belt tensioner that applies tension to the drive belt.
The best tool to use for this job is the serpentine belt too.
If you can borrow one from a neighbour you can get one at PartSource. (Part# 648451)
On other models you will have to loosen the adjusting bolt on the alternator bracket.
If you're not sure about how to remove the drive belt, visit your local PartSource for free print outs of car specific instructions.
Take off the mounting bolts from the alternator bracket
Now remove the alternator from the engine compartment
Installing Your New Alternator
Put the alternator in the engine compartment
Install the mounting bolts that connect the alternator to the alternator bracket
Connect the alternator wiring harness
Now connect the positive wire to the alternator
NOTE: Your new alternator should come with a retaining nut.
Remember to remove the nut before you install the positive wire.
If it doesn't keep the old nut.
Connect the ground wire to the alternator
Now install the drive belt
This is a great time to replace your old worn out belt. When inspecting your old belt look for signs of cracking, oil soaked, hard glazed, splitting or fraying.
All these signs mean it's time you replaced your drive belt.
If your vehicle no longer has the belt routing diagram under the hood, visit your local PartSource for a free print out of the belt routing diagram.
Reconnect the ground battery cable .
Feb 19, 2011 | 2003 Ford Focus
I have a 99 montero sport 4wd. Well i went to change the alternator i thought the tesioner was right next to the alternator sp i loosened it and it fell off and im not sure exactly how it goes back...
Belt routing and mounting brackets can be like Rubiks' Cube. Stop by dealers' parts dept and ask if they can photo copy exploded view of belt routing for you. This will show you all parts and how they're mounted.
Jan 07, 2011 | Mitsubishi Montero Sport Cars & Trucks
Hello everyone. I bought garmin nuvi 750 GPS six months ago. I use it travelling all over and it works pretty good. But I dont know how could i find alternate route for same destination. For eg. I want to...
What you're looking for is called "Via Points" as your friend correctly suggested. From the Garmin Nuvi 750 web based information:
nüvi 750 includes advanced navigational features to take the worry out of traveling. With route planning you can save 10 routes, specify via points and preview simulated turns on the 750's wide screen. In addition, nüvi 750 automatically sorts multiple destinations to provide an efficient route for errands, deliveries or sales calls.
"Alternate routes" are those routes that are created when the nuvi is used with a traffic receiver (FM or MSDN). This allows for a new route to be created with the traffic data so that routes suffering congestion, etc. are avoided. Some people also refer to the routes created when a turn is missed (the GPS indicates "Recalculating") as an "alternate route" but it is not.
Jun 17, 2010 | Garmin nuvi 750 GPS Receiver
Serpentine tensioner bolt has sheared can this unit be replaced without removing the front of the vehicle .also is it true that the clutch in the alternator is the probable cause for this issue.2004 tdi...
To remove a tensioner of serpentine routing belt isn.t nessecery to open vehicles front.Ofcourse this is difficult job but it is possible.About the alternator.s clutch-some issues in this year have clutch but it is very easy to check.Just look on an alternator puley.If there is round plastic cover that means this is clutch if not - regular one
Apr 24, 2010 | 2004 Volkswagen Passat
Can i program a route that i normally take instead of the route the gps gives me
After you program your destination using 'Navigate to...', you can specify your specific instructions by using 'Find alternative' -> 'Travel via' and/or 'Avoid part of the route' until the generated route largely satisfy your requirements. then finally, 'Calculate alternative'
Hope it helps: let me know how you go.
Jan 07, 2010 | Tomtom ONE GPS Receiver
How to install 03 ford focus alternator?
Removing the Alternator
If you're not sure about how to remove the drive belt, visit your local PartSource for free print outs of vehicle specific instructions.
Now remove the alternator from the engine compartment There. You've removed the alternator. How easy was that?
Nov 19, 2009 | 2003 Ford Focus
Alternator Belt routing
hey tony , i tried to highlight for the distinction between the 2 belts , red for alt , and blue for p/s . hope you can follow my drawing .
J5
Jan 20, 2009 | 1992 Ford Aerostar Extended
Home Logo
958 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
