Question about KitchenAid Dishwashers
We cannot start the dishwasher, the light child lock is on.
It in-built model. Always worked perfect. Sudden problem without apparent reason: we cannot lock properly the door and bthe light "child lock" is on when door closes.
    Sergeant:
  • 305 Answers
Disengage the childlock
Posted on Dec 20, 2014
catriver
  • 878 Answers
SOURCE: cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Posted on Oct 15, 2006
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
SOURCE: My Frigidaire dishwasher will not start.
This solution worked for me too. Thanks for the money saving solution!!
Posted on Feb 06, 2010
GodBlessU
  • 3513 Answers
SOURCE: How do you get the child lock off?
Please find complete process to switch off the child lock.
http://www.ehow.com/how_5144877_turn-kitchenaid-dishwasher-child-lock.html
Most of the dishwashers are same so the model should not be a problem
Thanks
Posted on May 17, 2010
  • 6 Answers
SOURCE: samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Posted on Jun 22, 2012
Testimonial: "thanks, ill try that now"
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Dishwasher will not start. The only light that comes on is the "control lock." Model #: KUDP01DL
Press and hold the control lock key for about 10-30 seconds, or until it goes off. This is the "child lock out" mode.
Apr 27, 2011 | KitchenAid 24 in. KUDP01DL Built-in...
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
How to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 08, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have model #KUDS24SEBL-l. The child lock light
Press and hold the "Energy Saver Dry" button for 5 seconds to turn the Child Lock on/off. I hope this helps you.
Oct 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
GE Profile built in dishwasher problem
Try cutting the breaker off for 5 min, This will reset the control.
Mar 14, 2008 | GE Profile PDW8400J Built-in Dishwasher
Hot to set the child lock
try holding down the engergy save dry button for three seconds
Jan 27, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Jan 20, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Setting cycles and turning dishwasher on
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Jan 17, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
205 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
