Question about Coffee Makers & Espresso Machines
How can I fix the steamer on my coffee machine
Tried unscrewing steamer nozzle to machine. there is no blockage in the end piece
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Have you tried descaling the machine? You can get a descaler in the super market. That works for me.
Posted on Dec 10, 2014
No steam from nozzle
If their is steam pressure in the boiler them the number one problem is a blockage even if you think this is not the problem. The blockage is likely to be in the steam pipe and is likely to be a bit of scale,,, I would try removing the steam pipe and unscrew the jet from the end then attempt to blow through both the jet and the pipe separately,,, to locate the source of any blockage. If you find a blockage soak the part in a strong solution of citric acid overnight or longer. A strong vinegar may also soften the scale then you should be able to clear it with a long fine piece of wire.
Good luck with getting it sorted!
Sep 27, 2017 | Coffee Makers & Espresso Machines
My steamer is not working properly
Take the nozzle off and wash well also there is a small hole pin size at the top clean out with a pin and push the black inside piece inside nozzle out 2/3 MM out it must pop out I use a chop stick it's perfect. I had the same problem perfect now
Nov 07, 2015 | Gaggia Titanium Espresso Machine
Milk Steamer/Frother
Take off the end bit; it unscrews. Poke a needle through the hole; I find it gets blocked quite regularly. While it's disconnected turn the knob on the right. Steam should come out. If it doesn't there is a blockage inside the machine and you need to get inside it to fix it. But the only blockage I've had is in the end bit.
Jan 07, 2014 | FrancisFrancis! X5 Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Dec 16, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steamer nozzle not working
  1. take a piece of wire and clean steam pipes holes than try it
  2. check the termofuses and steam swich
Oct 24, 2008 | Rancilio Audrey
STEAMER NOT WORKING - Hi my francis coffee machine is having problems with steaming.  Everything else works apart from getting steam/froth.  I have descaled it lots but still not working.  What can I do?
Hi again, I looked at some other posts on this site and tried soaking the steam wand in a cup of boiling water with a cap of vinegar in it.   I left it about 20 minutes and it worked very well.   My problem was just that the wand was blocked with dried milk on the inside.  I'll make sure to run water through after steaming milk in future .....
Aug 06, 2008 | FrancisFrancis! X1 - Stainless Steel...
Ex20 coffee maker
Please look the procedure for "Making Espresso Coffee " and for "Making Cappuccino" at http://www.coffeecrew.com/content/view/186/27/ and http://www.coffeecrew.com/content/view/187/27/
I hope this work for you.
JC Contin
Jun 10, 2008 | Salton EX20 Coffee Maker, Espresso Machine
Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Jan 18, 2008 | Solis Crema SL-70 Espresso Machine
Steam wand not working
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
Coffee Makers & Espresso Machines Logo
85 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
