Question about Garden
How do you remove the choke assembly from the handle of the choke on the mower body i have disconnected it from the throttle
Model # 917.289472
  • 22 Answers
The Choke handle/knob is fastened to the dash of a riding mower either with a clip behind the dash or a nut and washer around the assembly. The clip can be removed with needle nosed pliers . The nut can be removed with a wrench that fits the nut and holding the cable with pliers as a back up. After this the cable will come out thru the dash.
Posted on Dec 11, 2014
L300 Saturn 2003 trying to replace my throtter sensor. Can't figure out where to start from. Have no idea where's it located.
Your vehicle has electronic throttle control an the Throttle position sensor's are internal to the throttle body assembly ! Your vehicle has two throttle position sensors .
Throttle Body Assembly
The throttle assembly contains the following components:
?€¢ The throttle blade ?€¢ The throttle actuator motor ?€¢ The throttle position (TP) sensor 1 and 2 You have to replace the Throttle Body Assembly !
Disconnect the negative battery cable. Remove the inlet hose assembly from the throttle body. Disconnect the throttle body electrical connection. Disconnect the hose clamps from the plenum-to-runner connector using theJ 43914 .
Remove the intake plenum bolts. Remove the EGR passage bolt. Rotate the plenum up and remove the throttle body coolant hoses, EVAP hose, and vacuum line from the throttle body.
Remove the throttle body nuts. Remove the throttle body.
Aug 05, 2015 | Saturn Cars & Trucks
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Replace choke on garden tractor 917.289472
It has small spring clips around the base of the pull knob end on the inside of the operator station that must be depressed to remove choke cable assembly
Dec 10, 2014 | Sears Garden
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
Throttle body sensor location 2005 uplander
the sensor is part of the throttle body and not replaceable here is the throttle body replacement instructions as you will have to replace the entire throttle body it is a very common issue with these
THROTTLE BODY ASSEMBLY REPLACEMENT
REMOVAL PROCEDURE
  1. Remove the air cleaner intake duct.
120434113
  1. Disconnect the electronic throttle control (ETC) electrical connector (1) from the throttle body (2).
113356645
  1. Remove the heater pipe nut at the throttle body.
  2. Remove only the heater inlet pipe.
113356646
  1. Remove the nuts and the bolts from the throttle body.
  2. Remove the throttle body assembly.
  3. Remove the throttle body gasket.
  4. Clean and inspect the throttle body gasket mating surfaces.
NOTE: Do not use solvent of any type when cleaning the gasket surfaces on the intake manifold and the throttle body assembly, as damage to the gasket surfaces and throttle body assembly may result.
Use care in cleaning the gasket surfaces on the intake manifold and the throttle body assembly, as sharp tools may damage the gasket surfaces.
INSTALLATION PROCEDURE
113356646
  1. Install a new gasket, if necessary.
  2. Install the throttle body assembly.
  3. Install the throttle body nuts and the bolts.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the nuts and the bolts to 10 N.m (89 lb in) .
113356645
  1. Install the heater inlet pipe.
  2. Install the heater pipe nut to the throttle body.
Tighten the nut to 25 N.m (18 lb ft) .
120434113
  1. Connect the ETC electrical connector (1) to the throttle body (2).
  2. Install the air cleaner intake duct.
Feb 03, 2014 | 2005 Chevrolet Uplander
My 96 nissan sentra shuts down at times in idle at stop light, allready installed new plugs roter and plug wires
Disconnect the air ducting between the air filter box and the throttle. Clean your throttle body interior with a cloth and plenty of carb choke spray (WD40 is good too). Idling is controlled by the engine's computer and the Idle Air Control Valve IACV . This device allows air passed the closed throttle plate when the engine is at idle. Locate the inlet port in front of the throttle plate in the inside wall of the throttle body. Locate the IACV on the outside of the throttle and remove it. Give it and associated passageways a really good clean. Make sure the valve and valve seat are free of crud. Re-assemble and this should cure the problem
Sep 21, 2010 | 1996 Nissan Sentra
Where is the carb on a jeep grand cherokee 1993 4.0 liter
There is no carburetor on any of the 6 cylinder or 8 cylinder Jeep Grand Cherokees. They have Fuel Injection and a throttle body which looks like a carburetor scaled down.
Instructions on how to remove and replace the throttle body follow:
Throttle Body REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the vacuum hoses from upper bonnet, unfasten the retaining clips and remove the upper bonnet assembly.
  3. Remove the lower bonnet retaining bolts and lower bonnet.
  4. Remove the throttle cable and the return spring.
  5. Disengage the wire harness connector from the injector.
  6. Disengage the wire harness connector from the WOT switch, ISA motor and TPS.
  7. Disconnect the fuel supply and return lines from the throttle body.
  8. Tag and disengage the vacuum hoses from the throttle body assembly.
  9. Disengage the potentiometer wire connector.
  10. Loosen throttle body retaining bolts and remove throttle body assembly from the intake manifold. To install:
  11. Clean the intake manifold and throttle body mating surfaces of old gasket material.
  12. Install a new gasket and the throttle body assembly. Tighten the mounting bolts to 16 ft. lbs. (21 Nm).
  13. Engage the potentiometer wire connector.
  14. Engage the vacuum hoses to the throttle body.
  15. Engage the fuel lines to the throttle body.
  16. Engage the WOT switch, ISA motor, TPS, and injector electrical connections.
  17. Install the return spring and throttle cable.
  18. Install the lower bonnet and fasten the retainers.
  19. Install the upper bonnet assembly, retaining clips and vacuum hoses.
  20. Connect the negative battery cable.
  21. Start the vehicle and check for fuel leaks. Fig. 1: Exploded view of the throttle body and related components 86745g41.gif
Aug 17, 2010 | 1993 Jeep Grand Cherokee
I got the screws off for the door handle on the ACO1860AS Microwave but the handle will still not come off. Is there another mechanisme or hidden screw that needs to come out?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
From the service manual:
Door Disassembly
1. Disconnect power to oven and remove oven door,
(see "Door Removal" procedure).
2. Pry away choke cover, by placing a tool in the upper
right corner of the door and gently prying outward on
the choke cover. Continue to work around the door
casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to
release plastic tabs from door frame. Once latch
assembly is loose the spring may be disconnected
from the door frame.
4. Remove screws securing door handle and door
frame to door panel.
5. Remove door frame by releasing tabs around entire
door panel.
Remove door handle by placing a hand on door panel
next to the top of the door handle. Twist door panel
towards the inside of door and pulling on the top
portion of the door handle in a quick jerking motion.
NOTE: When replacing door handle, the bottom portion
of the door handle must be inserted first.
You can find handy exploded views and order parts by model number here.
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Installing throttle cable on Husqvarna 445 chainsaw
Try blocking the throttle arm on the carburetor in the wide-open position with a small stick, then deal with the trigger mechanism. In order to remove the cable from the carburetor, you need to remove the carburetor itself, then unhook the cable end at the throttle arm. Keep track of which fuel hose goes where if you do this. Hope this helps!
Mar 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I cannot locate the throttle position sensor on my 2000 catera
THERE IS NO CONVENTIONAL TPS, THROTTLE POSITION IS PART OF THE DRIVE BY WIRE SYSTEM IN THE THROTTLE BODY ASSEMBLY
Aug 26, 2009 | Cadillac Catera Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
