Question about Hardware & Accessories
I need directions on how to program my Utilitech 15-amp 6-outlet digital lighting timer
I lost the instructions on how to program.
    Top Expert:
  • Hardware & A... Master
  • 44,097 Answers
If possible, return to the place of purchase and find out whether they will make a copy of the instructions for you.
Posted on Dec 10, 2014
How do I program a Utilitech timer UTTNOCD2(154182)?
Lowe's has the instructions for the UTTNOCD2 (154182) on the product page: https://www.lowes.com/pd/PRIME-15-Amp-2-Outlet-Mechanical-Residential-Plug-in-Countdown-Function-Lighting-Timer/4177013 . Expand the Guides & Documents section. The direct link to the instructions is http://pdf.lowes.com/useandcareguides/054732816729_use.pdf .
After plugging in the timer, you need to rotate the black dial (clockwise or counter-clockwise) until the desired setting is lined up with arrow (at about 11 o'clock on a 12 hour analog clock). The choices are On, Off, On at dusk for the desired number of hours (even number of hours), or On at dusk and Off at dawn.
I hope this helps.
Dec 07, 2017 | Hardware & Accessories
I need the English instructions for the Utilitech timer #0144506
I found a Utilitech timer at Lowes with the item number #0144506. The Utilitech model number for this timer is UTTNID001. If this is the correct timer, the manual is on the product page: https://www.lowes.com/pd/Utilitech-15-Amp-1-Outlet-Digital-Residential-Plug-in-Lighting-Timer/4740850 . Scroll down and expand the Guides & Documents section. The direct link is currently: http://pdf.lowes.com/useandcareguides/054732817825_use.pdf .
I hope this helps.
Nov 23, 2017 | Hardware & Accessories
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
Timer is probably wired incorrectly.
Copy following links for correct wiring, and larger instructions.
I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 31, 2012 | Hardware & Accessories
I connected out door X mas lights to the Utilitech 3 outlet photocell timer. the lights went on at dusk, as they were supposed to. But they started blinking on and off. what is worng?
Unfortunately someone went to great lengths to copy/paste the wrong instruction guide to this solution. Like me, the OP has a 3 outlet PHOTOCELL timer, not a 2 outlet DIGITAL timer. Photocell determines dusk/daylight/etc. We also have the same issue. Wondering if has to be connected directly to outlet. Ours worked fine when plugged into outlet. When we moved it after Xmas to run year-round lights, plugged into extension cord and problems began. No response to date on emails sent to mfg.
Nov 12, 2011 | Hardware & Accessories
WHERE CAN I FIND DIRECTIONS TO PROGRAM TIMER #0148373
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 19, 2010 | Hardware & Accessories
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Instructions:
Turn ON lamp.
Light bulb is good.
Dec 30, 2009 | Kitchen Appliances - Others
How do you program the utilitech 1-outlet daily timer
How do you program the Utilitech Outdoor 6-outlet Stake Timer
Dec 01, 2009 | Day-Timer Hardware & Accessories
Hardware & Accessories Logo
304 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
