Question about Sears Garden
Replace choke on garden tractor 917.289472
I have disconnected the choke cable from the throttle but cannot disconnect it from the chop of the mower
  • Sears Master
  • 1,169 Answers
It has small spring clips around the base of the pull knob end on the inside of the operator station that must be depressed to remove choke cable assembly
Posted on Dec 10, 2014
Garden tractor
sounds like your choke is not shutting all the way. Throttle pushed all the way up should shut the choke, if you can look into the intake of the carb to see if the butterfly is shut and if not loosen the cable sheath clamp and side the cable until it does shut it and make sure the lever is still in the full throttle position
May 30, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
How do you remove the choke assembly from the handle of the choke on the mower body i have disconnected it from the throttle
The Choke handle/knob is fastened to the dash of a riding mower either with a clip behind the dash or a nut and washer around the assembly. The clip can be removed with needle nosed pliers . The nut can be removed with a wrench that fits the nut and holding the cable with pliers as a back up. After this the cable will come out thru the dash.
Dec 10, 2014 | Garden
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Exmark lazer choke won t engage
check cables from lever to carb make sure it is not pinched it should be a tube w another cable running trough it that moves back and forth or broken even disconnected
Jan 24, 2014 | Garden
Replace throttle cable on simplicity mower
how do you get the throttle and choke cables out of the dash on a simplicity conquest
Feb 02, 2013 | Briggs & Stratton Garden
Craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Oct 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Riding mower wont run unless choke is full on and dies when choke is shut off
Probably a failed or disconnected fuel shut-off solenoid. It's located on the bottom of the float bowl. Check that there is battery voltage present when ignition is on. If so, solenoid has either failed, or jammed due to gum build-up.
May 10, 2010 | John Deere 3010,3020 Tractor Basic...
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Choke cable 3020 won't pull out. seems to be stuck. sprayed with lubricant. no luck
hello,
If you have sprayed the cable with lube you need to make sure the cable is actually freed up you will have to disconnect it from the choke linkages in the engine, if when you do this the cable moves freely then you know the problem is in the linkages themselves lubricate all these untill it all moves freely...
Hope this helps
Kind Regards
Brad
Dec 30, 2009 | John Deere 3010,3020 Tractor Basic...
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Garden Logo
57 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
