Question about Bose Audio Players & Recorders
Is Bose companion 5 multimedia syatem a fuse type? If not, how do I fix this?
  • 1,249 Answers
yes, inside the unit.
Posted on Dec 10, 2014
Bose repair
Does not seem very complex. I think it is because of the broken fuse. Simply Open the back part of Bose companion 5. The Circuit board attached to the back part is basically for the Audio output socket, Control pod Connector and Power supply connector. on the Left hand side of the board you will find a fuse soldered with the board. most probably that fuse is broken. replace the fuse if broken or just connect both end of the fuse with thin wire (temporary) to check. Hope it helps.
I am outta home or else i could have added an image for you. maybe tomorrow.
Thanks
Jun 23, 2014 | Bose Companion 5 Multimedia Speaker System...
Where can i get bose power supply distribution circuit?
I have a companion 5 . I bought it in UK hence 220 volt out needed . I move to Venezuela where Volt out let is 120 volt . It doesnot work due less power available . what can I do
Dec 26, 2012 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 doesn't work with OS 10.6.4. Help!! How can I fix it???
i am not sure it is the OS because since it is software it doesnt really select hardware such as speakers. try checking to ensure your connection is correct or the sound system is still functioning, you can try it on another pc
Oct 10, 2010 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Does a companion 5 bose speaker have a fuse?
You will need to change entire power supply/distribution circuit since you have managed to fry it all with twice the voltage required by the system. Speakers should be OK only the circuitry needs to be rectified and too by a professional/expert technician ...........sodeep
Mar 31, 2009 | Bose Companion 5 Multimedia Speaker System...
79 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
