I have a panasonic viera TH-58PZ700U Why am I hearing a high pitched humming sound when I turn it on I did a vusual check of the boards and capacitors ?
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
There are many reasons for this fault. Your TV need a through check-up. Contact any service technician. This is not a user repairable fault.
Its power supply section circuit should be checked. Usually; a hum sound can be with any fault filter capacitors on it. But can't say; it will be. As I stated above, there might be any other reason that this. I think that you can get me. In fact; trouble-shooting should be started from the main power supply regulator board itself. Ok?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 10, 2014
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Posted on Jan 05, 2009
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
Posted on May 16, 2010
Panasonic th-42px600u high pitch sound
likely a coil or small transformer in the set is vibrating hard enough to make it squeel, it would have to be located with back off by listening to see where it comes from.
cure would be to replace the entire board it is on or hot glue the part that is causing this to dampen the sound.
If it is coming from the front screen unit that is a more serious issue.
Dec 23, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
TH58PZ700U
Hello
check its power supply regulator board for any loose solderings.
This is the picture of the power regulator board to your tv. Normally there is no repair for this board, and if it is found faulty, card base replacement can be done. If there is some loose soldering contacts, it can be resoldered by applying a little more solder. that is all. OK.
Jan 02, 2012 | Panasonic Viera TH-58PZ700U TV
Our panasonic tv green light flashes
If your TV flashes green light..try to count how many flashes and what is the sequence to diagnose where exactly fault came from..
Dec 12, 2011 | Panasonic Viera TH-58PZ700U TV
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Jan 18, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Wont power up led flashes 7 times
If this is an LG TV this is down to the power supply within your TV, this needs to be replaced - you should contact your screen manufacturer for more advice.
Sep 13, 2009 | Panasonic Viera TH-58PZ700U TV
Panasonic 50" Viera plasma on/off problems
its the problem in main board.any of the capacitors or ic are getting overheated that needs to be checked and replaced. thanks.
Jul 13, 2009 | Panasonic TH-50PX500U 50 in. Plasma...
Panasonic viera making noise from the back even with tv sound off
That is often a capacitor on one of the boards making that sound.  It is actually normal and does not usually mean that there is anything wrong with the TV.  This happens often with computer parts and well, and sometimes gets as bad as a high pitched squeal.
Mar 30, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
