Question about Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White
Replaced heating element. Dried one load of clothes and element went out again. What could be the problem?
  • 4,349 Answers
The likelihood of a second element failure is very remote, unless the element suffered some damage, like bending or chipping.
It seems more likely that you have a thermal limiter that is opening. There can be two or more, and they are in series with the power to the element.
Unplug the dryer and test the thermal limiters.
Another area to look at is the control switch. Long story short, there is a ton of current going to the element. The contacts in the switch can carbon up and overheat.
Posted on Dec 10, 2014
I have a Kenmore fabric care 220 dryer cleaned the left side sensor started to heat went cold again
Heating elements could be going bad. Or the high temp fuse is out. Check the fuse for continuity and inspect the element for any breaks in the wiring
Jul 28, 2015 | Kenmore Dryers
Dryer not working
check to see if your vents are clogged its the num. 1 reason. if they are most likely your thermal fuse blew out, have it replaced. Another reason is your heating element went bad. Check for continuity on both items.
Apr 16, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool wed5600sq0 I bought in 2007 never dried my clothes. There seems to be two heating elements in the rear drum. The larger one doesn't seem to heat up. Is this the problem? Is this a heating...
i think you will find that the heaters are in the front of the drum not the back,,,are the inlet and outlet pipes clear of dust and fluff some times its the heat sencors that have packed up on you it wont heat at all then,if any of the elements have falied it will still heat up a little but will take years to dry a full load
Oct 24, 2009 | Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
I changed the thermal cutoff. it dried one load and then wouldnt heat again
check the thermo again, it might be going out due to a short in the element, or obstructed venting causing too much heat, clear venting or replace therm/heating element if needed.
Jun 30, 2009 | Dryers
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer blowing thermostats.
your vent is holding heat and it cause it to burn out and also check the element itself
Dec 01, 2008 | Kenmore 659 Electric Dryer
Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
