It has a little red light on the lower right hand side of TV that is lite up for child safety lock I have had it unplugged for over 24hrs tried plugging it back in hopping light would go out but it still comes on and still will not power back up at all just a black screen no power it also has a VCR tape inside that I can't eject out I seen someone said to push button on remote to turn safety lock off but I don't have the original remote to do that
  • 3130 Answers
SOURCE: samsung tv vcr combo
according to the info I have on that set theres a front panel control key theres also a lcd display?? as I see the picture you may have locked the set with this control key?? if this dosent work go online and look up samsung LTP179DW remote controls or contact samsung directly at and go to customer assistance. Hope this helps ya!
Posted on Apr 02, 2006
SOURCE: Child Locked the TV
* If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. * If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels. * If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688. One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again. If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
Posted on Jan 13, 2007
  • 308 Answers
SOURCE: EWC1304 VHS tape shuts off entire system
You probably have a bad or dirty mode select switch. Another possibility would be a gear out of time if a tape was forced in too quickly.
Posted on Mar 12, 2007
  • 1139 Answers
SOURCE: TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Posted on Sep 06, 2007
SOURCE: TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Posted on Aug 04, 2009
Frigidaire microwave ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep. Keypad not responding to presses. Unplugged the unit the problem r
Hey JT Tai, I appreciate your post!
The symbol at the top left hand side of your display could be child lock symbol or vent symbol. If it is the child lock you should be able to press and hold the stop/cancel button down for 3 seconds to release the child lock.
If the light is on for the vent I would seek assistance from a professional for proper diagnosis and repair to be completed on your microwave. I hope this is helpful. -Matt
Oct 12, 2014 | Frigidaire Microwave Ovens
How do I disengage the Child Lock on the NEC VN214 DVD/VCR player? The manual tells us how to but the picture of the remote looks slightly different to the remote we have.
on your remote down on the left hand side at the bottom of it its the second last button called c.lock its right above easy rpt press n hold till the little red key flashes and disapears off your unit !
Depending on the model of you hardware, you can generally
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Jun 21, 2011 | NEC Televison & Video
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
NEC NDT-40 DVD/VCR how to turn off "child lock"
Jul 07, 2010 | NEC NDT44 DVD Player/VCR
I Bought a brand new lamp bulb for my hitachi 50VS69A. I simply tried to insert it. Looked simple enough. And the tv won't come on . But the red Lamp Light on the front of the tv is flashing intermitently...
Seems simple enough for me the one that spent 1 hr and a half pulling out my hair on that question lol lol hhaaaaaaaaaaaaa there is Did you put the safety cover back on the back of the lamp panel if so make sure you push it all the way back over untill it locks.there is a safety switchonthe right lower tab (small white piece of plastic inside the hole) that will cause the lamp light to stay on.don't thank me thank my wife which ask me thousands of questions on why the tv doesn't work what could it be??????????? until holding my head in my hands and staring blankly at the hole where the bulb goes when i saw that little tab of white and there it was.....hope this helps you or someone else out......
Jun 18, 2010 | Televison & Video
Chid door lock doesn't work, I try to put it to normal pos
I had the same problem when I changed out my window regulator. Take the door apart remove lock and make sure the rod is connected to the little white piece on back of the child safety lock not under it or in the bottom of your door which is enabling it not to move at all because it is not connected this will fix your problem make sure not to knock the window pin out of place wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Mar 28, 2009 | 2003 Jeep Liberty
Apex tv pf2030 child lock
I'm afraid you will need the original remote control hand unit folks. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jan 19, 2008 | Apex Digital PF2025 20" TV
Unable to unlock Centrex tv model CTT6809SF
Try holding down the + symbol on bottom right hand side of controller for more than 4 secs
Jan 01, 2008 | Televison & Video
Whirlpool Front Load Duet Dryer
Elsewhere on this forum a fix was given that is rather easy. Someone in your home has activated the child safety switch. On the lower right hand side of the control panel, hold the bottom button in for 3 seconds until the light goes out.(safety control lock switch)
Nov 11, 2007 | Dryers
Televison & Video Logo
Top Televison & Video Experts
