Question about Zenith Televison & Video
27" Zenith SEQ - sound is not always clear lately unless I turn it up loud - Is this repairable at a reasonable cost?
    Top Expert:
  • Zenith Master
  • 74,251 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Dec 10, 2014
I have an old zenith sentry tv, and up to know has never had any problems. Afew days ago it started making a very loud noise as soon as I turned it on. It sounds like it's coming from the right
someone needs to open it but it sounds like a part arcing which was not uncommon in those sets====you would have to decide if you want to attempt to have it repaired----some shops will not repair a set that old and unless you really want it done---I would replace it.
Mar 17, 2012 | Zenith Televison & Video
1997 Zenith tv, 27" i cannot find a remote or proper access code that will work on it.
Try out the Harmony remote - tad more expensive but very flexible and comprehensive.
Sep 06, 2017 | Zenith Televison & Video
Zenith Plasma
My TV has a picture but its very poor quality and its fading ,blurry color it is not clear what can i do to fix.Thanks
Jul 21, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith 27inch B28A11Z keeps powering itself off
Hi Pswglaw,
From the way you describe the problem, it seems you have a high voltage leak. To check this, make the room dark and look into the back of the TV while turning it on. If you see something like lighting jumping around you have this high voltage problem. The TV will eventually destroy itself under this condition. I would suggest not using it until you get it repaired. The repair cost will be much lower if the TV is still working when you take it in. The high voltage leak will destroy more parts and cause the TV to stop working. Then it will blow a fuse.
MyTvGuy
Jan 23, 2008 | Zenith B27A11Z 27" TV
No remote
heidib, if the front of the set has a menu button try going in and autoprogramming your channels, it seems odd that it won`t go above or below channel 2 which tells me none of the other channels are programmed in. Good luck
Nov 27, 2007 | Zenith C27A24T 27" TV
Zenith 27 TV - screen jumps and suddenly turns off.
Sounds like you have a vertical failure, and is causing the power supply to shut down. A repair person can probably repair this main board in this set but it will cost more in time and labor to repair. So the right thing to do is replace the entire module. This Zenith was designed to replace the boards completely to shorten down time as well as labor. The board this set needs is a 9-02107 module, and is avail from http://www.partstore.com for 52.44 + shipping. I dont think you should attemp to do this repair by yourself if you have no electronics training or tv training. This is just so you know what you need and get an idea on what this will cost you to repair. Good Luck
Aug 13, 2006 | Zenith C27A24T 27" TV
My Zenith B27A11Z Does not display a Picture or audio sound only a load pitch sound apon turning on
The best thing I can recommend is to seek an estimate as we cant teach ya how to fix the set as your aware of and second is if its gonna cost alot then buy a new one . Sorry couldnt be of more assitance man. Good Luck
Jun 13, 2006 | Zenith B27A11Z 27" TV
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Tv blew up
sounds like the typical power supply or sweep problem in the zenith chassis. depending on how old this set is will determin if its even worth trouble shooting or taking it in to be looked at by a pro. If your not experienced with tv repair i would call a repair shop or take it in as tv sets have high voltage stored in them even after they have been unplugged for a while. If youve tinkered with tvs in the past or know someone who does zenith tvs are made for a complete chassis exchange. you can Call PTS Corp at 1 800 844 7872 and see how much an exchanged referbished chassis would cost and go from there. Good Luck
May 24, 2006 | Zenith A27A23W 27" TV
Broken RF Connector
Its fixable. the question is how much of the inside broke with it. cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job Good luck
Mar 09, 2006 | Zenith C27A24T 27" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
