How do I adjust the pressure - Heating & Cooling
    Master:
  • 755 Answers
On what
Posted on Dec 10, 2014
Pump comes on at 30psi and off at 42 psi. Is there a way to adjust the lower set pressure so it will come on at say 22 psi? Goulds model c48a93a06
Most pump pressure switches have adjustment screws or springs with adjustment nuts on them. Usually there are two. One to adjust the on pressure and one to adjust the differential that is the pressure dideference between off and on usually about 20 psi
when you remove the cover look inside the cover there is usually a diagram identifying the adjustment screws or nuts. Hope this helps
Bob
Nov 04, 2014 | Plumbing
Adjust square d water pressure switch
Adjust pressure
http://waterheatertimer.org/images/Pressure-switch.jpg
Use 3/8" wrench
Turn power off
Remove cover
There are two locknuts
Center nut screwed inward raises pressure... water well will cut off at higher pressure
Left-side nut adjusts range between cut on and cut off pressure
Sep 29, 2014 | Square D 9013gsg2s22j99r Pressure Switch
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
How do you adjust the on-off pressure settings on this switch?
Unfortunately you didn't give the complete number. There should be 3 more numbers like J15 etc. Anyway, remove the cover. Use a nut-driver and adjust the large nut for the CUTOUT pressure. If your turn the nut clockwise (tighten or turn it in) it will increase the cutout pressure. If you turn it counter clockwise (loosen or turn out) it will lower the pressure. This the pressure that will turn the unit off. If your model has an adjustable differential, it will be the smaller nut. This will be the CUT IN pressure. It will adjust the same as the other adjustment.
http://www.schneider-electric.us/products-services/product-detail/?event=productDetail&partNumber=9013GSG2J15&countryCode=us
Oct 10, 2010 | Square D 9013 Gsg2 Pressure Switch Nnb...
How do i adjust air pressure cut out
Square d recommends that the pressure switch be adjusted to specifications of the particular switch (which is sold in pressure ranges preset at the factory). The switch will be erratic it adjusted out of the factory setting range.
From Square D: (adjust the desired cut-in pressure first, then cut-out)
Cut-in: The large spring controls the cut-in pressure. To make adjustments, turn the nut clockwise (compressing the spring) to raise the cut-in point or counterclockwise to lower the point of cut-in.
Cut-out: The small spring is the differential adjustment and controls the cut-out pressure. To raise the cut-out pressure turn the small nut clockwise (more differential); to lower the cut-out pressure turn counterclockwise.
Sep 24, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Low pressure and pump pressure adjuster makes no difference
Replace the pressure adjuster and everything will work. When you lose pressure and the adjuster is not adjusting to allow more or less then you need to replace it. It has a valve in there that is most likely broken and the valve is not opening and closing anymore.
Please rate
Jun 01, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Adjusting the pressure on the 2340-E
most air compressors have a pressure switch on them.this is used to adjust the desired pressure you want to reach.the second adjustment is for setting the pressure for when you want it to cycle back on.lets say you want it to run at 100 PSI.one of your adjustment in this box will control this , when you are using the unit and the pressure starts to drop to lets say 90 PSI you can adjust the unit to cycle
Oct 29, 2009 | Ingersoll Rand - Rand Type - 30...
How to test a pressure sensor switch on a air compressor
Hi, W/D here.
To accurately test a switch, it has to be removed from the compressor and tested by raising the pressure and lowering it with air supplied from a known, good regulator. The trip pressures are then noted and adjusted.
The quick and dirty way of "getting close enough" is a little different. Start the compressor, and when it gets to your desired cutoff pressure, pull the plug. Adjust the HP spring untill the contacts trip out. Now, with the compressor still unplugged, drain the pressure off of the tank until you reach your desired cut in pressure, and close the valve. Adjust either the LP cut in or the differential pressure adjustment to set the cut in pressure. The contacts will pull in. If you adjust the cut in pressure with the diff pressure setting, the cut out pressure has to be challenged and set again. Whichever method you follow, you always need to check the upper and lower settings after each adjustment.
Best regards, --W/D--
Aug 13, 2009 | Dewalt D55153R Reconditioned 1.1 HP...
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
