Burner will not come on but pilot works and stays lite. The fan also works
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If you have a voltmeter, with the thermostat in the heat position and turned several degrees above room temperature, check for 24volts across terminals W and C. If you do not have 24 v there, the problem is in the thermostat or the wires between the furnace and the thermostat.
If you do have 24 volts between W and C, the problem is in the furnace....No idea what brand of furnace you have or whether or not its a high efficiency or not, so here's some generic things to look for.
Look for a "manual reset limit switch" in the furnace vestibule or towards the top inside on the front panel. Also some manufacturers have a manual reset limit switch mounted on the blower. Check for 24v on the gas valve...if its a three terminal valve, the middle terminal is usually a dummy. The two outside terminals should be the 24v to the coil that causes it to open on a call for heat.
Oh yeah, once the pilot was lit manually, make sure the knob was rotated from "pilot" to the "on" position.
You could have open pressure switch caused by a vent blockage if its high efficiency. But if its high efficiency, there should be a set of LED's to blink a failure code. If so, count the blinks and look for the list of failures on the inside of the door of the furnace.
Posted on Dec 11, 2014
VN18TB PILOT LITE GOES OUT STAY LITE TILL HEATER COMES ON AFTER THE HEAT RUNS AND TURNS OFF THE PILOT LITE SHUTS OFF NATURAL GAS VANGUARD
Sounds like a weak thermocouple. With the extra heat of the main burner running it can keep the pilot solenoid open...without it it fails shut. Try replacing the thermocouple. (small rod the pilot flame burns against with a skinny copper tube going to gas valve).
Jan 04, 2010 | Heating & Cooling
Pilot stays lite but the burner wont ignite propane unit
the gas is not coming out of the burner, probably due to rust clogging the holes.
Dec 04, 2009 | Water Heaters
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Can't get the pilot to stay lite after I turn the knob to the "on
sounds like a thermocouple its a metal proble looking thing nex to the pilot light with a small copper tube attached to it that goes back to the burner control.
Aug 04, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Gas-Pilot stays on, but main burner shuts off 10 min
A polit generator produces about 750 MV without a load. Under load it will drop to about 200-250 MV. If the system is working don't worry about it. If the system is not working replace the pilot generator and retest. Pilot generators usually go bad slowly.
Jun 22, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot light stays on but burner doesnt ignite
usually the small opening on the burner that 'points' to the pilot light will get clogged with cleaning soap or spills. Look carefully (the burner may be very easy to remove for inspection. There should be a small hole on the side pointing toward the location of the pilot light. It will be lower down than the main burner openings. Clean it out with a wooden toothpick.
Jun 19, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
No able to lite pilot
make sure gas supply is there also clean the thermocouple, if it is fowled or dirty the pilot wont stay lit nor will the main gas valve open
May 24, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars lite 2 pool heater burner not lite
If the pilot flame is not strong enough, it will not tell the gas valve to open, or if the gas valve is not getting the signal to open, it won't. Check all wire connections at the thermostat and gas valve. Check ground wires. Clean the pilot light and flame rod.
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
