Question about Frigidaire FMV157GB Over-the-Range 1.5 Cu. Ft. Microwave Oven, Black, 1000 Watts / 10 Power Levels, Add-Thirty Seconds, Cooking Surface Light, Digital Cooking Display, Color-Coordinated Control Panel and Door with Window, Touch Control with 24 Pads, 1 Auto-Defr
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
Shorted out the lights attempting to unscrew a burnt out bulb. Now neither light will light.
  • 1,511 Answers
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Posted on Dec 10, 2014
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Interior light bulb burned out
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Oct 31, 2013 | Samsung SMH8165STE Microwave Oven
Light bulb
follow this steps and fix it. God bless you
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    The lamp of won't work
    follow the steps and fix it. God bless you
    ight Bulb
    If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
    Main Control Board
    If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
    Light Bulb Socket
    If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
    Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
    I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
    That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
    Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
    It also sounds like your bulb is an assembly - the socket and bulb and one piece.
    So your local appliance parts store should have a generic replacement for it. You should take the bulb.
    Be careful when disconnecting the leads.
    Apr 14, 2013 | GE Microwave Ovens
    Counter top lights not working. new bulbs replaced. still not working.
    We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95.
    At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
    The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
    Sep 04, 2012 | Panasonic NN-H275SF Microwave Oven
    Microwave Cooktop / Night Light not working
    I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
    Mar 06, 2012 | GE Microwave Ovens
    My light bulb has stopped working and will not work after I have replaced it with a new one
    It could be either a separate door switch for the light that's gotten crufty (sometimes just cleaning them makes them serviceable) of the microwave that needs to be reset. Just check for tripped circuit breakers, since you've already unplugged the thing to swap the bulb (I expect.) Then check your bulb's continuity, then check the socket and switch functions if things aren't sorted.
    Sep 10, 2011 | Whirlpool MH1141XM Microwave Oven
    Light won't go on; Model MMV1153WB-O
    You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
    Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
    Or just get it here, to be more exact.
    On page 4, it says:
    "Installing/Replacing Filters and Light Bulbs
    ■ Grease filter: Grease filter is on the underside of microwave
    oven. Clean monthly. Slide the filter away from the tab area,
    and drop out the filter. To reinstall, place end of the filter into
    the opening opposite the tab area, swing up the other end,
    and slide it toward the tab area.
    ■ Charcoal filter: The charcoal filter is behind the vent grille at the
    top front of the microwave oven. The charcoal filter cannot be
    cleaned, and should be replaced about every 6 months.
    Remove 2 screws on the vent grille, tilt the grille forward, lift it
    out, and remove filter. To reinstall, place the filter into its slotted
    area – wire mesh side up, replace vent grille, and secure with
    screws.
    ■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
    the underside of the microwave oven, and is(are) replaceable.
    Remove bulb cover screw, and open the bulb cover. Replace
    bulb, close bulb cover, and secure with screw.
    ■ Cavity light: The cavity light bulb is located behind the vent
    grille at the top front of the microwave oven, under the bulb
    cover, and is replaceable. Remove 2 screws on the vent grille,
    tilt the grille forward, and lift it out. Open bulb cover and
    replace bulb. Close bulb cover, replace vent grille, and secure
    with screws."
    HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
    You can find links to helpful exploded view diagrams and part ordering help here.
    I recommend that you bookmark that link to your favorites. Hope this covers it.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    May 06, 2010 | Maytag Over-the-Range Microwave
    Frigidaire FMV157GB Over-the-Range 1.5 Cu. Ft. Microwave Oven, Black, 1000 Watts / 10 Power Levels, Add-Thirty Seconds, Cooking Surface Light, Digital Cooking Display, Color-Coordinated Control Panel and Door with Window, Touch Control with 24 Pads, 1 Auto-Defr Logo
    119 people viewed this question
    Top Frigidaire Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
