Question about Archos 101G9 Android Internet Tablet
My tablet does not switch ON
The screen do not appear even though the indicating lamp for power is continuoulsy glow
  • rajan mathew
    rajan mathew Dec 13, 2014
    i have recharged , the power status LED continously glow ( ie fully charge) but still screen do not appear . did battery failed
    New Friend:
  • 33 Answers
Do a complete hardware reset, search goolge how to hardware reset your tablet.
Posted on Dec 13, 2014
  • rajan mathew
    i pressed the volume button while powering ON, the screen is not illuminated
My son's tablet is less than 4 months old and it keeps shutting off even when fully charged. It is a 9 inch nextbook and was purchased at Walmart.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Feb 23, 2017 | Nextbook Tablets & eReaders
I am not able to turn on my kindle after serveral hours of being plugged in to charge
Your Kindle may not be actually charging even though it appears to be. Mine has been charging since previous reading session and currently is showing green indicator. Occasionally, I will have the Kindle connected to charge only to discover later that the charger has worked loose from the power strip. Hope you can get this problem solved so you can catch up on your reading.
Aug 16, 2016 | Amazon Kindle Fire HD
Kindle will not turn on even tho its bee charging 5 hours
Soft Reset:
Hold the power switch for twenty seconds. You will need to slide the power switch along and hold it for twenty seconds before releasing it. ...
Your reboot screen should appear when you release the power switch.
Give your device time to reboot for a minute or two.
Turn the Kindle Fire HD back on.
Jan 01, 2016 | Amazon Kindle Fire HD
Have been charging it for over 24 hrs it wont turn on?
If a little lamp is lit when you plug in the charger (indicating that the device is charging), then try holding the power button down longer until something appears on the screen. If no lamp is lighting when you plug in the charger then there is something else wrong. Check it is the right power supply for the device and that you are plugging into the correct hole of the device (not the earphone connector). It also may be the charger itself is not working.
Mar 05, 2015 | Tablets & eReaders
My Linx 7 tablet keeps dying even if I;m not using it. Constantly needs to charge can I change the settings to stop this
Are you actually turning the tablet off when you are not using it? (Hold down power button until Power Off box appears on screen)? If not, your tablet is constantly using power even with the screen blanked and will drain the battery. You could have a bad battery that is no longer holding its charge. How long can you run the device off the charger continuously? That length of time might indicate the state of the battery. Check the manual for expected battery life, which for a Linx 7 is usually 4 hours or less.
Jan 19, 2015 | HP Tablets & eReaders
How can i fix my dell venue 8 pro? It won't turn on at all.
Seems to be a common problem.
You are on the right track with holding down power button.
1. Hold down for 20 secs, Wait 5secs, hold down for up to 10 secs, it may turn on before then.
2. Does the screen have a dim glow, even though there is nothing on it?
Let it discharge itself so the glow is gone, may take some hours.
Plug it into charge for at least 30 mins.
Try to turn it on.
More info here
http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/why-wont-my-dell-venue-8-pro-windows-tablet-turn/50573983-8cb7-4770-bf5c-478e63ec5cf8
Jun 07, 2014 | Tablets & eReaders
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
I have upgraded my tc1100 to 1.5Gs of memory. The description on the memory module is ( Super * Talent D400SBG/H STT DDR-400 PC3200 SO-DIMM Hynix 1G/64X8). The problem is the computer initially boots into...
It sounds like that memory should be compatible with your tablet PC. It may be a bad memory stick -- try to replace it with a different memory stick (preferably from a different manufacturer) and see if it still gives you the same problem.
If you didn't have this problem before you installed the new memory, a different memory stick will likely correct the issue. You can also try removing the new memory and see if the PC boots up like it should.
Dec 08, 2010 | Compaq tc1100 Tablet PC
I can't get any display on the screen of my pc.The power is working very well and all the led indicators are on. No sound during POST, and I have tried connecting a screen through the external screen port....
  1. please follow the following instructions i hope this helps
  2. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  3. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  4. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning
Jul 12, 2010 | HP Pavilion TX1320US Tablet PC
Archos 101G9 Android Internet Tablet Logo
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
