Question about Canon imageRUNNER 1310 Printer
How do I make a copy using the bypass tray with card stock on the canon image runner 1310?
I only know how to use the drawer tray. I do not know how to use the bypass unless I'm printing something from the computer.
    New Friend:
  • 10 Answers
You have to select the paper tray(in this case bypass)when you make a copy.
Posted on Dec 10, 2014
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
My Canon Image runner 2318 keep jamming paper even no paper is not jammed
is this problem only when u copy from the tray or even from bypass.if it is from tray only then ur rubber feedrolls needs to be cleaned with simple wet cloth.if it is from both then u have to check the paper path sensor
Jul 13, 2011 | Canon imageRUNNER C3200 Copier
Getting ghost images on copies, meter reading is approx 2000 copies.
Ghosts are normally caused by the fuser but with such a low meter, we'd look elsewhere. Try changing paper or feeding a regular sheet through the bypass tray at a card stock setting.
If the ghosts disappear then that proves that the fuser issues are the best suspects. The fuser/ fixing assembly PN is FG6-7947-150 if it ends up that it's bad.
Whit
Item, Inc.
Aug 17, 2010 | Canon imageCLASS D661 Digital Printer
I need to know what is the kind of drum a Imagerunner 1630 uses.
An OPC Drum is used, you can use Drum of these models image runner 1310, 1330. 1370, 1510, 1530, 1570
Mar 29, 2010 | Canon Image Runner 1630 Copier Copier
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
We just received some used Canon Image runner 1310 copier/printer and I not have it hooked up to my computer. It is printing just a little off....it slants to one side. Any idea's why?
hi, wel now that you have two questions i still working on your first :P
this copier may only take paper from two diferent trays.
one is named the multi-purpose tray an dthe other just the cassette.
so i gathered you want to print using the MP tray, right? to copy from the bypass (or MP) tray, just choose it using the paper select button (take a look at the panel, there's a button that actually says 'paper select') . now if you want to print from it, go to your printer settings and change the default paper source to the mp tray.
about the other problem im still trying to figure out your problem.
Jan 28, 2009 | Canon imageRUNNER 1310 Printer
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
How do I change the paper size of the paper source in canon image runner 5570
Just enter the paper stock that you want to use and adjust the guides. The machine should pick up the size if it's in universal cassettes. If it's the bypass, you select 'paper select' then select the bypass and choose the size that you want.
Jul 31, 2008 | Canon Image Runner 3320I Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Canon imageRUNNER 1310 Printer Logo
74 people viewed this question
old marine
old marine
